HDD GURU FORUMS
http://forum.hddguru.com/
pcb compatible?
http://forum.hddguru.com/viewtopic.php?f=11&t=29630
Page 1 of 1
Author:  DRCP [ September 28th, 2014, 12:14 ]
Post subject:  pcb compatible?
HI GUrus,
is PCB 2060-771824-008 REv P1 WD5000AZRX-00A8LB0(This is faulty PCB)
& PCB 2060-771824-003 Rev A WD30EZRX-00DC0B0 COMPATIBLE ?
Can i use PCB 2060-771824-003 Rev A WD30EZRX-00DC0B0 as donor for PCB 2060-771824-008 REv P1 WD5000AZRX-00A8LB0 as donor?
Thanks in advance
attachments.zip [8.92 MiB]
Downloaded 4596 times
Author:  Dmitri [ September 30th, 2014, 13:59 ]
Post subject:  WD5000AZRX / WD30EZRX pcb compatible?
Yes, if MCU tagging, PCB tagging and PCB revision are the same.
http://www.phpbb.com/
