 Post subject: WD10EARX-00PASB0 (Sadle G6) module 2E kind request
PostPosted: October 12th, 2014, 2:28
Hello to everybody
for an
Consolidated ROM version................ : 00200088
I'm searching for module 2E,
The drive goes DRD DSC and reads quite fast all the modules, both copies, but then at any sector access it goes ARB ERR. As a matter of fact, SA Structure test return that module 2E is corrupted (also a couple more, but they are reported as non critical)
Also, the download section for Sadle G6 doesn't host any WD10EARX-00PASB0 but there are some WD20EARX-00PASB0 and I'm wondering if their module 2E could match the one I'm seeking for.
Thank you for any hint or for the module itself
Cor
 Post subject: Re: WD10EARX-00PASB0 (Sadle G6) module 2E kind request
PostPosted: October 12th, 2014, 2:48
Sorry wrong ROM
ROM version is 002000A6
FW: 51.0AB51
PostPosted: October 12th, 2014, 7:28
Hello islamm3rouf
thank you so much for your availability
if you have it, please attach it to your reply here in the forum
but kindly, please also confirm the resource details (disk model, fw version and rom version)
Thank you
Have a good Sunday
Cor
PostPosted: October 12th, 2014, 8:58
This module not's used in Sadle G6
header of the module you can do to fix the plugin of complex.
PostPosted: October 12th, 2014, 9:52
agree with Tomset . this is log module and it's useless and it doesn't affect data at all. Sadle G6 is tricky some how . try to Chang head map in ram and back the original again .
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: October 12th, 2014, 14:33
Bingo!
Suspect head is probably causing improper translator initialisation.
