 Post subject: \WDC WD5003ABYX-18WERA0-01-01S04 ROM SUMT RE
PostPosted: November 11th, 2014, 15:28
Please Rom
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1264
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 512 Kb
>ROM version............................. : 06.8PB
>ROM generation.......................... : 06.8QB
>Link table version...................... : 01.2U.
>Consolidated ROM version................ : 0006008P
>ROM Modules:
>Flash ROM dir reading................... : Ok (Active)
>Modules directory address............... : 101 746 (24)
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : default
>Heads map............................... : default
>ROM Firmware version.................... : 000500A2
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0
Нет ничего невозможного
 Post subject: Re: \WDC WD5003ABYX-18WERA0-01-01S04 ROM SUMT RE
PostPosted: November 12th, 2014, 7:06
I dont have this one, sorry.
PostPosted: November 12th, 2014, 7:11
I have never used PC3k but out of curiosity I'm wondering what these ROM-requests are. HDD-ROMs for a specific drive with the hope that someone else with PC3k has dumped from a drive with matching values?
PostPosted: November 13th, 2014, 6:36
here is one.
good luck
ROM.zip [414.85 KiB]
Downloaded 485 times
Data Recovery Pakistan
PostPosted: November 13th, 2014, 7:07
MindMergepk wrote:
here is one.
good luck
Ok thanks! :mrgreen:
will test!
