Discussions related to PC-3000
Please no pirated software here!
PCB compatibility for TOSHIBA drive
January 28th, 2018, 9:35
I have a Toshiba DT01ACA3000 (JAN-2016)
PCB Sticker:
PF00035
TS0242C
K1N549
01B2
PCB REF: 220 0A90380 01
I bought a new PCB with REF 220 0A90380 01 (but I don't know the HDD model).
I transferred the ROM but unfortunately, the PCB didn't work.
Could anyone please, tell which parameter have to match between the patient and the donor PCB for that drive.
Thanks in advance.
Re: PCB compatibility for TOSHIBA drive
January 28th, 2018, 10:44
Well,
i try n match pcb no ,Main MCU chip and motor controller
January 29th, 2018, 3:08
Thank you for your reply,
I tried that. the PCB I bought had the same PCB number, Main MCU chip and motor controller but unfortunately, it didn't work.
January 29th, 2018, 3:21
1. what does didn't work mean ?
motor spins up ?
gets RDY ?
2. can you read the NVRAM from the old PCB using PC3K ?
January 29th, 2018, 8:45
jermy wrote:1. what does didn't work mean ?
motor spins up ?
gets RDY ?
No, in PC3K, the BSY light is OFF when I power on the drive. the drive doesn't spin at ALL.
No, I can't read the NVRAM as the PCB is not working at ALL.
January 29th, 2018, 15:20
@sosrecup, did you not dump/backup the ROM/NVRAM after you removed it?
My approach would be to determine why the original PCB failed, and whether there is a problem with the preamp or motor. That's assuming that you did not damage the chip with your soldering.
January 29th, 2018, 15:35
@sosrecup, if can't solve it on your own, I would go with @fzabkar
but as as stated above, need to know:, if the NVRAM/motor/preamp is intact
as an alternative, if you have a matching PCB (example: the donor WITH the original ROM/NVRAM)
try first a cold swap ans see what going on
and same goes here, need to know:, if the NVRAM(patients)/motor/preamp is intact
January 30th, 2018, 0:34
@fzabkar
The original drive has a overvoltage and I can see some burnt electronic component.
I tested the Ampere between the coils of the drive, and the motor doesn't seem to have a problem.
@jermy
the question I'm asking, is what are the matching criteria for PCB for that drive?
@Spildit
The PCB I bought works fine with it's original ROM. when I plug it into PC3K, BSY light is GREEN.
When I plug only the PCB with the Patient ROM, the BSY light is GREEN too.
But when I plug the drive, no answer and no green light (even for BSY)
January 30th, 2018, 2:02
If you upload hires photos of both sides of the PCB, I could show you where to test the preamp.
January 30th, 2018, 3:15
see PCB from both sides.
January 30th, 2018, 5:00
I think these are the +/-5V supplies.
You should measure the resistance between ground and each of the +5V and -5V test points. Compare your two drives and PCBs.
AFAICT, there is some damage to the Vcore supply in the photo. Have you tested the TVS diodes and fuses? That should tell you if an overvoltage was to blame.
January 30th, 2018, 19:44
Spildit wrote:If you can't see a single register with the drive plugged to the PCB then something is "shorted" preventing the PCB from working at any level.
sometimes (in PC3K) you got no light AT ALL when "PCB only" (even a good working one) is connected, but it doesn't mean anything
hoops, actually (when you get all the lights turned off) it means its ready and "can" read ROM/NVRAM/CPs
January 30th, 2018, 20:48
Spildit wrote:Are you sure about this ?
yes sir (not always, but most of the time)
the way to get those green lights to normal, is to send a soft reset
a bad PCB signal = "all" the lights are light green
