Firebird mod 11 required (WD10JMVW-11S5XS0)
http://forum.hddguru.com/viewtopic.php?f=11&t=30036
Author:  pcimage [ November 26th, 2014, 10:52 ]
Post subject:  Firebird mod 11 required (WD10JMVW-11S5XS0)
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 03.52C
ROM generation.......................... : 03.53B
Link table version...................... : TP.46.
Consolidated ROM version................ : 00030052
ROM Modules:
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 70 867
SA regions address...................... : by default
SA Translator loading................... : Ok
SA defects assigned..................... : 14
Heads configuration..................... : by map
Heads number............................ : 4
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 00030052
Thanks!!
Author:  MindMergepk [ November 26th, 2014, 11:02 ]
Post subject:  Re: Firebird mod 11 required (WD10JMVW-11S5XS0)
here is complete FW+ROM
good luck
WDC WD10JMVW-11S5XS0 01.01A01 WD-WX81A7243796.zip [13.6 MiB]
Downloaded 746 times
Author:  pcimage [ November 26th, 2014, 15:16 ]
Thanks!!
I got the mod 11 already and drive cloning now :-)
