HDD GURU FORUMS
http://forum.hddguru.com/
FBLite Ldr required
http://forum.hddguru.com/viewtopic.php?f=11&t=30124
Page 1 of 1
Author:  pcimage [ December 9th, 2014, 12:09 ]
Post subject:  FBLite Ldr required
WD10JMVW-11AJGS2
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 16.1VH
ROM generation.......................... : 16.1VH
Link table version...................... : NA.31.
Consolidated ROM version................ : 0016001V
ROM Modules:
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 110 006
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 0016001V
Thanks!
Author:  pclab [ December 9th, 2014, 13:23 ]
Post subject:  Re: FBLite Ldr required
This is for C version.
Want to try?
11.rpm.zip [468.96 KiB]
Downloaded 500 times
Author:  Tawfeek [ December 9th, 2014, 13:27 ]
sorry i have 00160014 . 00160015 . 0016001C
Author:  labtech [ December 9th, 2014, 13:33 ]
http://files.hddguru.com/index.php?acti ... rd%20Lite&
Author:  pcimage [ December 10th, 2014, 8:05 ]
Thanks!
Worked fine, drive working now :-)
Author:  labtech [ December 10th, 2014, 8:45 ]
Nice, another happy customer and $$ in the pocket
Author:  pcimage [ December 10th, 2014, 15:40 ]
Still plenty to do on the case, mind you.
Drive was dropped whilst running and so has media damage. :-(
Author:  labtech [ December 10th, 2014, 15:56 ]
Never easy, right?!?
Media damage fighting is so tiring..
http://www.phpbb.com/
