 Post subject: Loader for WD10JPVT-75A1YT0 - urgent
PostPosted: November 24th, 2014, 18:11
Firebird 2.5" family
View ROM information
ROM Data size........................... : 256 Kb
Firmware version........................ : 0003004A
Urgent!
 Post subject: Re: Loader for WD10JPVT-75A1YT0 - urgent
PostPosted: November 24th, 2014, 18:41
I have FW version 00030052 or 00030038 but not the 4A
Might be worth trying if you want.
PostPosted: November 24th, 2014, 19:06
Maybe this helps - same family - not my resource, just noticed it
http://files.hddguru.com/index.php?acti ... /Firebird&
PostPosted: November 24th, 2014, 19:47
Thanks friends. I will try it from labtech link and let you know.
PostPosted: November 24th, 2014, 20:05
Here's the two I have if you want to try them.
WD10JPVT-75A1YT0 Loaders.zip [808.41 KiB]
Downloaded 447 times
PostPosted: November 25th, 2014, 7:45
I have one for 0003000M.
Test it.
11.rpm.zip [406.52 KiB]
Downloaded 480 times
ACELab partner
PostPosted: November 25th, 2014, 9:17
Here is loader from the version you want.
Best of luck.
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 4
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1420
>ROM:
>ROM reading............................. : Ok
>ROM version............................. : 03.4AB
>ROM generation.......................... : 03.4BB
>Link table version...................... : TP.46.
>Consolidated ROM version................ : 0003004A
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Flash ROM dir (ext) reading............. : Ok (Active)
>Modules directory address............... : 214 608 (32)
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 4
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3
>ROM Firmware version.................... : 0003004A
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.rar [402.21 KiB]
Downloaded 556 times
PostPosted: November 25th, 2014, 9:35
i have the match one 0003004A :wink:
0003004A.rar [382.98 KiB]
Downloaded 512 times
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: November 26th, 2014, 14:43
Thanks for all! So far data not recovered, probably I have issue with heads too.
PostPosted: December 19th, 2014, 18:39
Finally case was solved. Problem was with head compatibility.
