| Looking a loader to WD3200BEVT http://forum.hddguru.com/viewtopic.php?f=11&t=30181 |
Page 1 of 1 |
| Author: | barak [ December 18th, 2014, 13:02 ] |
| Post subject: | Looking a loader to WD3200BEVT |
Hi gurus, I'm looking a loader to WD3200BEVT-60ZCT1 Denali. Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 4 Cyl Count............................... : 128 ROM: ROM reading............................. : Ok ROM Data size........................... : 192 Kb ROM version............................. : 08.30D ROM generation.......................... : 08.30D Link table version...................... : 02.14. Consolidated ROM version................ : 00080030 ROM Modules: Flash ROM dir reading................... : Ok SA regions address...................... : by default SA Translator loading................... : Ok SA defects assigned..................... : 8 Heads configuration..................... : by map Heads number............................ : 4 Heads number in use..................... : 4 Switched off heads...................... : No Heads map............................... : 0,1,2,3 ROM Firmware version.................... : 00080030 Thank you all for your time and support! |
| Author: | Adrian84 [ December 18th, 2014, 14:03 ] |
| Post subject: | Re: Looking a loader to WD3200BEVT |
>Techno mode key >Techno mode key......................... : Ok > >RAM: >HDD Info reading........................ : Ok >Heads number............................ : 4 >Cyl Count............................... : 128 > >Zone allocation table................... : Ok >SA SPT.................................. : 693 > >ROM: >ROM reading............................. : Ok >ROM Data size........................... : 192 Kb >ROM version............................. : 08.31D >ROM generation.......................... : 08.31D >Link table version...................... : 02.14. >Consolidated ROM version................ : 00080031 > >ROM Modules: >Flash ROM dir reading................... : Ok >SA regions address...................... : by default >SA Translator loading................... : Ok > >Heads configuration..................... : by map >Heads number............................ : 4 >Heads number in use..................... : 4 >Switched off heads...................... : No >Heads map............................... : 0,1,2,3 >ROM Firmware version.................... : 00080031 > >Service area: >Permanent overlay....................... : Loaded >SA dir reading (ID)..................... : Ok >SA Access............................... : Copy 0,Copy 1 > Hello. Is this going to help you ? slight difference |
| Author: | pcimage [ December 19th, 2014, 4:50 ] | ||
| Post subject: | Re: Looking a loader to WD3200BEVT | ||
Here's Version 00080030 from an 80Gb drive, should work....
| Author: | barak [ December 19th, 2014, 14:52 ] |
Thank you all, public and private messages were helpful. This one turned out to be bad head(s) though. |
