Loader for WD10JMVW-11S5XS1
http://forum.hddguru.com/viewtopic.php?f=11&t=30191
Author:  arvika [ December 19th, 2014, 18:42 ]
Post subject:  Loader for WD10JMVW-11S5XS1
Firebird family.
View ROM information
ROM Data size........................... : 256 Kb
Firmware version........................ : 00030080
Looking for LDR.
Author:  Mikippp [ January 5th, 2015, 12:20 ]
Post subject:  Re: Loader for WD10JMVW-11S5XS1
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
Zone allocation table................... : Ok
SA SPT.................................. : 1437
ROM:
ROM reading............................. : Ok
ROM version............................. : 03.80C
ROM generation.......................... : 03.81C
Link table version...................... : TP.4J.
Consolidated ROM version................ : 00030080
ROM Modules:
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 74 442
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 00030080
Service area:
Permanent overlay....................... : Loaded
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
Mikippp
11.zip [412.28 KiB]
Downloaded 659 times
