| Need LDR For ST9500325AS http://forum.hddguru.com/viewtopic.php?f=11&t=30262 |
Page 1 of 2 |
| Author: | hyuce [ January 5th, 2015, 10:31 ] |
| Post subject: | Need LDR For ST9500325AS |
Hi, i need LDR. anyone help? ST9500325AS fw: 0002BSM1 Thanks. |
| Author: | hyuce [ July 11th, 2015, 10:03 ] |
| Post subject: | Re: Need LDR For ST9500325AS |
Still looking for this. |
| Author: | michael chiklis [ July 14th, 2015, 5:50 ] |
I don't have loader for this but i have ROM, SA mods and tracks of this: ST9500325AS fw: 0002BSM1 s/n: 5VExxxxx Family: Wyatt if you know how to build a loader from tracks i can send you fw resources of this. Which tools do you have for hdd fw working? |
| Author: | michael chiklis [ July 21st, 2015, 13:52 ] |
When i did backup fw resource of this drive i forgot to generate the loader, but with MRT it's possible to generate loader file from tracks. I don't know if PC3000 generates loaders from tracks, with MRT it's possible to generate it via tracks or via terminal or via ATA. I don't have this drive anymore because i gave back to customer, so the only way i can generate the loader for you is via tracks, hope it will work with your PC3000. FW resource included LDR file, made with MRT, hope it will work for PC3000: Attachment:
| Author: | michael chiklis [ July 21st, 2015, 17:18 ] |
Some pics to show you how i created LDR by track in MRT... Attachment: Attachment: Attachment: LDR3.JPG [ 23.4 KiB | Viewed 29834 times ] Attachment:
| Author: | hyuce [ July 22nd, 2015, 6:32 ] |
thank you Michael. i tried that Ldr but not working on PC3K. |
| Author: | michael chiklis [ July 22nd, 2015, 9:46 ] |
i'm sorry for that probably it's because MRT ldr is not compatible with pc3000, or because MRT ldr is just garbage (mrt is full of bug). Inside rar file that i sent to you there are mods, rom and tracks generated in MRT (which are perfectly compatible with PC3000), you should ask into PC3000 forum if someone knows how to build a loader without having the drive physically but by using just firmware resource. Or just ask directly the loader in PC3000 forum... P.S. Rom version of loader should match with your patient drive rom or it might not work. Good luck! |
| Author: | pcimage [ July 22nd, 2015, 9:55 ] | ||
| Post subject: | Re: Need LDR For ST9500325AS | ||
Try this...
| Author: | fzabkar [ July 22nd, 2015, 13:24 ] |
ISTM that the LOD file is similar in structure to those that come with Seagate's F3 firmware updates. These appear to consist of headers plus various modules. The layout in this particular case is as follows: Code: range size description ---------------------------------------------------- 0 - 001FF 200 header 200 - 301FF 30000 track 41, offset 0 - 2FFFF 30200 - 303FF 200 header 30400 - 503FF 20000 track 41, offset 30000 - 4FFFF 50400 - 505FF 200 header 50600 - 605FF 10000 ~001E.rpm 60600 - 607FF 200 header 60800 - 707FF 10000 ~001D.rpm ISTM that you could manually generate a loader, if you could understand the structure of the headers. |
| Author: | fzabkar [ July 23rd, 2015, 3:29 ] |
I think I've worked out how to construct the headers. The header contents are actually embedded within each of the 4 modules. Only minor changes are required. The Python script at the following thread provides a little insight into the structure: http://www.hddoracle.com/viewtopic.php? ... 219&p=5825 In fact it is a simple matter to extract a complete loader from Seagate's firmware update packages. |
| Author: | michael chiklis [ July 23rd, 2015, 3:49 ] |
Very interesting Frank Unfortunately i can't find any firmware update for Momentus 5400.6 drives on Seagate web site How should be used Python script? |
| Author: | fzabkar [ July 23rd, 2015, 3:59 ] |
The Python script doesn't generate or extract the loader per se. I only referred to it because its coding illuminated the header structure. If you need a loader for the 5400.6 drive, I can try to create one for you from the modules and tracks. |
| Author: | hyuce [ July 23rd, 2015, 4:10 ] |
thank you all, case solved but i interested now, how can create loader from the modules and tracks. |
| Author: | michael chiklis [ July 23rd, 2015, 6:16 ] |
hyuce, you have solved with pcimage LDR ? It's nice reading when people have solved an issue @fzabkar I don't need a loader for this drive, i was just tring to help hyuce and also to understand how to build LDR manually. Would be interesting to know how you would build it if you don't have firmware update resource as for this 5400.6 drive |
| Author: | fzabkar [ July 23rd, 2015, 6:21 ] |
The loader consists of 4 firmware modules, namely 1D, 1E, and two modules on track 41. The first module is located at offset 0x200 and is preceded by a header of size 0x40 bytes. Code: Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 000001C0 71 78 37 07 00 00 00 00 00 3C 00 01 04 00 4A 00 qx7......<....J. 000001D0 00 00 03 00 0D 60 02 00 99 00 01 00 06 10 09 20 .....`..™...... 000001E0 00 00 00 00 40 00 03 00 00 00 00 00 00 00 00 00 ....@........... 000001F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C B2 ...............² 00000200 04 00 00 00 06 61 40 FC 00 00 03 00 02 00 00 00 .....a@ü........ 00000210 30 82 10 06 00 00 00 00 00 00 00 00 00 00 0F 06 0‚.............. 00000220 44 F2 2F 00 FF FF FF FF FF FF FF FF FF FF FF FF Dò/.ÿÿÿÿÿÿÿÿÿÿÿÿ 00000230 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF ....ÿÿÿÿÿÿÿÿÿÿÿÿ 00000240 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ 00000250 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ 00000260 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ 00000270 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ........ 000301E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 000301F0 00 00 00 00 00 00 00 00 00 00 00 00 77 FF 00 00 ............wÿ.. The header begins with a magic number, "71 78 37 07". Offset 0x1D0 contains the size of the data section, namely 0x30000. Offset 0x1E4 is the size of the data section plus header, namely 0x30040. Offset 0x1FE is the checksum word for the header. It is calculated in such a way that the 16-bit little-endian sum, including the checksum word, is 0x0000. Offset 0x1CC is the module ID, namely 0x0004, which is reflected in the first word of the data section. Offset 0x1CE is the data type, 0x4A. I believe this denotes an SA overlay. Offsets 0x1D8 - 0x1DF are the time/date stamp. The date is 2009/10/06. The header "template" can be found by searching for the magic number within the firmware module: Code: Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 0000F440 71 78 37 07 00 00 00 00 00 3C 00 01 qx7......<.. 0000F450 04 00 0A 00 00 00 03 00 0D 60 02 00 99 00 01 00 .........`..™... 0000F460 06 10 09 20 00 00 00 00 00 00 00 00 00 00 00 00 ... ............ 0000F470 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0000F480 00 00 00 00 .... Certain changes need to be made to this template, as explained above. Preceding each module and its 0x40 byte header is another 0x40 byte header with its own 0x180 byte data section: Code: Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 ................ 00000010 80 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 €............... 00000020 00 00 00 00 00 08 07 00 00 00 00 00 00 00 00 00 ................ 00000030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 72 F6 ..............rö 00000040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ........ 000001B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ This first header has a type of 0x07 (offset 0x0E). Offset 0x10 is the size of the data section, 0x180. Offset 0x24 is the size of the entire loader, 0x70800. Offset 0x3E is the checksum. Offsets 0x40 - 0x1BF constitute the data section, which is empty. Here is the next firmware module: Code: Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00030200 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 ................ 00030210 80 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 €............... 00030220 00 00 00 00 00 02 02 00 00 00 00 00 00 00 00 00 ................ 00030230 00 00 00 00 00 00 00 00 00 00 00 00 00 00 77 FC ..............wü 00030240 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ........ 000303B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 000303C0 71 78 37 07 00 00 00 00 00 3C 00 01 05 00 4A 00 qx7......<....J. 000303D0 00 00 02 00 0D 60 02 00 99 00 01 00 06 10 09 20 .....`..™...... 000303E0 00 00 00 00 40 00 02 00 00 00 00 00 00 00 00 00 ....@........... 000303F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0D B2 ...............² 00030400 05 00 00 00 0C C1 40 FC 00 00 02 00 02 00 00 00 .....Á@ü........ 00030410 CC 6C 13 06 00 00 00 00 00 00 00 00 00 00 12 06 Ìl.............. 00030420 08 64 33 00 FF FF FF FF FF FF FF FF FF FF FF FF .d3.ÿÿÿÿÿÿÿÿÿÿÿÿ 00030430 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ........ 000503E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 000503F0 00 00 00 00 00 00 00 00 00 00 00 00 4B 7B 00 00 ............K{.. The size of the data section is 0x20000, and the module ID is 0x05. One significant difference is in the main header. Whereas the first header contained the size of the entire loader, this header reflects the size of the firmware module plus the size of the all the header information preceding it (0x20000 + 0x200 = 0x20200). We repeat this process two more times for the remaining modules. |
| Author: | fzabkar [ July 23rd, 2015, 7:11 ] | ||
Here is an example where we extract the loader from the 0021LVM1 Lenovo firmware update for 5400.6 Momentus drives. It is included in the FWSH43 package (47MB): http://support.lenovo.com/us/en/downloads/ds003740 The relevant LOD image is 5421LV17.lod. It contains the loader plus several additional components. In this particular case the loader can be carved out from 0x00 to 0x707FF. The header needs to be edited to reflect the size of the loader (0x70800) rather than the size of the entire update (0xF3A00). This is the original header: Code: Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 ................ 00000010 80 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 €............... 00000020 00 00 00 00 00 3A 0F 00 00 00 00 00 00 00 00 00 .....:.......... 00000030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6A C4 ..............jÄ This is the modified one: Code: Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
| Author: | hyuce [ July 23rd, 2015, 8:54 ] |
@michael chiklis yep, case has solved with pcimage's LDR. @fzabkar wooow, very helpful information for us. Thank you!! |
| Author: | michael chiklis [ July 23rd, 2015, 11:21 ] |
Thank you Frank, i'm studing your post and soon i will try to generate some loaders as you did. |
| Author: | pepe [ August 22nd, 2015, 18:31 ] | ||
you might also enjoy this...
| Author: | fzabkar [ November 6th, 2016, 16:58 ] |
Tools for converting between old (LDR) and new (LOD) MRT Seagate F3 loaders: http://www.hddoracle.com/viewtopic.php?f=147&t=1772 Tool for creating Seagate F3 loader (LOD) from system files: http://www.hddoracle.com/viewtopic.php?t=1809 |
| Page 1 of 2 | All times are UTC - 5 hours [ DST ] |
