 Post subject: DDI to DE Map Conversion
PostPosted: January 11th, 2015, 13:46
Hi
I see in the DDI DRE that you can convert a DDI map to a DE map. It saves the file as a .bin file. How do I open this in DE? I presume I have to create a new task to create a new .prm file, but at what point do I insert the .bin file? This drive has been imaging on the DDI for some time so I don't want to risk messing anything up.
 Post subject: Re: DDI to DE Map Conversion
PostPosted: January 11th, 2015, 19:33
You create the new task, close your task and manually copy the bin file from DRE to task folder. Open task again.
That's all
Digitalsupport
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: January 11th, 2015, 20:16
That's all
Perfect Thanks.
PostPosted: January 12th, 2015, 13:57
That's all. Digitalsupport
This gives me an 'access violation error'.
I created a new task (copy)
Selected the DDI destination drive as the DE destination
Closed down the task
Inserted the .bin file into the task
Reopened the task
Get access violation error
Any ideas?
PostPosted: January 13th, 2015, 14:24
Try to select Map type as "Binary file" in DE copy task options.
Digitalsupport
PostPosted: January 13th, 2015, 14:31
digisupport wrote:
Try to select Map type as "Binary file" in DE copy task options. Digitalsupport
That worked. Many thanks.
