 Post subject: WD800JD-60LSA0
PostPosted: January 16th, 2015, 5:01
Hello
Could anyone provide the loader for WD800JD-60LSA0 hdd please
Kind regards
 Post subject: Re: WD800JD-60LSA0
PostPosted: January 16th, 2015, 5:12
What version?
PostPosted: January 16th, 2015, 6:10
PC3KUDMA auodetect model sabre58
PostPosted: January 16th, 2015, 6:18
PCB model 2060-701335-005 rev.A
File comment: HDD front label
PostPosted: January 16th, 2015, 7:00
PC3K reports this message at start
and the heads click until the motor stops
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 1
Cyl Count............................... : 64
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 128 Kb
ROM version............................. : 06.BSD
ROM generation.......................... : 06.BSD
Link table version...................... : 01.BC.
Consolidated ROM version................ : 000600BS
ROM Modules:
Heads configuration..................... : by map
Heads number in use..................... : 1
Switched off heads...................... : No
Heads map............................... : 1
ROM Firmware version.................... : 06BSD
Service area:
Permanent overlay....................... : Not loaded
SA dir reading (ID)..................... : Unknown error. Error code: 4341
PostPosted: January 16th, 2015, 7:12
What Walter means is what is the ROM Ver. ??
Please read carefully
PostPosted: January 16th, 2015, 7:30
Hi ROb thank for your attention
I posted the report.log of PC3K
PostPosted: January 16th, 2015, 7:39
PostPosted: January 16th, 2015, 8:23
Sorry, I don't have that version.
In any case, if the drive clicks and spins down then it's almost certainly a physical issue (e.g. heads bad)
