HDD GURU FORUMS
http://forum.hddguru.com/
WD800JD-60LSA0
http://forum.hddguru.com/viewtopic.php?f=11&t=30347
Page 1 of 1
Author:  walter1 [ January 16th, 2015, 5:01 ]
Post subject:  WD800JD-60LSA0
Hello
Could anyone provide the loader for WD800JD-60LSA0 hdd please
Kind regards
Author:  pcimage [ January 16th, 2015, 5:12 ]
Post subject:  Re: WD800JD-60LSA0
What version?
Author:  walter1 [ January 16th, 2015, 6:10 ]
PC3KUDMA auodetect model sabre58
Author:  walter1 [ January 16th, 2015, 6:18 ]
PCB model 2060-701335-005 rev.A
File comment: HDD front label
Author:  walter1 [ January 16th, 2015, 7:00 ]
PC3K reports this message at start
and the heads click until the motor stops
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 1
Cyl Count............................... : 64
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 128 Kb
ROM version............................. : 06.BSD
ROM generation.......................... : 06.BSD
Link table version...................... : 01.BC.
Consolidated ROM version................ : 000600BS
ROM Modules:
Heads configuration..................... : by map
Heads number in use..................... : 1
Switched off heads...................... : No
Heads map............................... : 1
ROM Firmware version.................... : 06BSD
Service area:
Permanent overlay....................... : Not loaded
SA dir reading (ID)..................... : Unknown error. Error code: 4341
Author:  ROb [ January 16th, 2015, 7:12 ]
What Walter means is what is the ROM Ver. ??
Please read carefully
Author:  walter1 [ January 16th, 2015, 7:30 ]
Hi ROb thank for your attention
I posted the report.log of PC3K
Author:  walter1 [ January 16th, 2015, 7:39 ]
Author:  pcimage [ January 16th, 2015, 8:23 ]
Sorry, I don't have that version.
In any case, if the drive clicks and spins down then it's almost certainly a physical issue (e.g. heads bad)
http://www.phpbb.com/
