need loader wd5000LPVX-55V0TT0 _ 0005001G
http://forum.hddguru.com/viewtopic.php?f=11&t=30380
Author:  pcimage [ January 20th, 2015, 10:17 ]
Post subject:  Re: need loader wd5000LPVX-55V0TT0 _ 0005001G
Here you go...
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1437
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 05.1GJ
>ROM generation.......................... : 05.1HJ
>Link table version...................... : N0.11.
>Consolidated ROM version................ : 0005001G
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Flash ROM dir reading (Ext)............. : Ok (Active)
>Modules directory address............... : 174 623
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>ROM Firmware version.................... : 0005001G
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.rar [426.28 KiB]
Downloaded 507 times
