 Post subject: WD10TMVW-11ZSMS0
PostPosted: May 4th, 2015, 18:16
Online
Hi
Does anyone have the ROM for this HDD?
Already got one, but didn't worked. I want to try another.
ACELab partner
 Post subject: Re: WD10TMVW-11ZSMS0
PostPosted: May 5th, 2015, 7:30
ROM for Helios can be 256KB or 512KB
PS The best is to specify the date of manufacture
Mikippp
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 6
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1108
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 512 Kb
>ROM version............................. : 02.0AA
>ROM generation.......................... : 02.0AA
>Link table version...................... : 01.0C.
>Consolidated ROM version................ : 0002000A
>ROM Modules:
>Flash ROM dir reading................... : Ok
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 6
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3,4,5
>ROM Firmware version.................... : 0002000A
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1,Copy 2,Copy 3
ROM.zip [481.55 KiB]
Downloaded 522 times
PostPosted: May 6th, 2015, 4:02
Online
Thanks Mikippp
I don't have it here with me now, but for what I can see this one has a diferent SPT from the one I got here from HDDGuru files.
I will try it.
ACELab partner
PostPosted: May 6th, 2015, 6:53
Hi pclab
I have this one
WDC WD10TMVW-11ZSMS5.rar [243.14 KiB]
Downloaded 572 times
Expect, the Unexpected
