 Post subject: FBLite 0005000T LDR required
PostPosted: March 16th, 2015, 11:49
Drive model: WD10JMVW-11AJGS0
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 05.0TH
ROM generation.......................... : 05.0TH
Link table version...................... : N0.0K.
Consolidated ROM version................ : 0005000T
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 281 368
SA Translator loading................... : Ok
SA defects assigned..................... : 1
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 0005000T
Cheers!!
Sean
 Post subject: Re: FBLite 0005000T LDR required
PostPosted: March 16th, 2015, 15:00
here you go attached
good luck
11.rar [424.78 KiB]
Downloaded 578 times
PostPosted: March 16th, 2015, 17:37
Thanks!
Will try it tomorrow :-)
PostPosted: March 17th, 2015, 4:06
Worked great, thanks!! :-)
PostPosted: March 17th, 2015, 9:10
good news
all the best :druunk:
