 Post subject: Seagate db35.4 ST3250310CS family
PostPosted: April 22nd, 2015, 18:26
Hello. One question: how can I find a seagate db35.4 ST3250310CS's family in PC-3000? Can't seem to find it. I repeat, is "...10CS", not "...10AS".
Thanks.
 Post subject: Re: Seagate db35.4 ST3250310CS family
PostPosted: April 22nd, 2015, 21:14
Barracuda 7200.10 NHawk Plus
PostPosted: April 22nd, 2015, 22:40
nope. that's ...10AS, not CS.
PostPosted: April 23rd, 2015, 0:36
What do you see via terminal?
PostPosted: April 23rd, 2015, 8:36
The models are so close that they will more than likely be the same family.
Can you post a pic of the cover?
PostPosted: April 25th, 2015, 8:32
Its not the same family. I've tried every single family and none of them work.
PostPosted: April 26th, 2015, 16:46
I select Seagate, and there are 3 big families. Can't remeber them. There were like 3'5, old 2'5 and another one. I've tried all and none work.
PostPosted: April 28th, 2015, 9:54
Spildit wrote:
What PC-3000 are you using ?
PIRATED PCI ???
:shock: :shock: :shock:
Of course is not pirated. I'll try on puty and let u know.
