WD5000BMVV 11GNWS0 MODULE 11
http://forum.hddguru.com/viewtopic.php?f=11&t=31465
Author:  shaikhmaula [ June 26th, 2015, 13:49 ]
Post subject:  WD5000BMVV 11GNWS0 MODULE 11
I have wD HDD model no :-WD5000BMVV 11GNWS0
the problem was it was getting detected but not showing me drive letter ,
it is Micro USB and MRTPRO dossent support micro USB so i imported Sata Card and change the U12 from Micro USb card to
Sata card , After this what i need to so i dont now need some one who can help me as i am new to this field.
Author:  digisupport [ June 26th, 2015, 15:42 ]
Post subject:  Re: WD5000BMVV 11GNWS0 MODULE 11
Post the ROM version for a LDR match
Maybee move this post to MRT section, maybe some one using MRT can guide you
Author:  shaikhmaula [ June 26th, 2015, 21:13 ]
WD WD5000BMVV-11GNWS0
while reading Rom i am getting this error
Technology mode key : ..........................:Err
RAM:
HDD Info Reading : .............................: Err
Zone allocation table : ........................: Err
ROM:
Read Rom Infos : ...............................: Err
ROM Modules:
Flash ROM dir reading : ........................: Err
Read 0A module : ...............................: Err
SA Module Dir Loading...
Load SA Module dir : ...........................: Error, suggest to load from the file
Configuration reading : ........................: Err
Author:  shaikhmaula [ June 27th, 2015, 7:52 ]
Family :- marn5 4K
Sa Cyl 256
head 2
SPT 1091
ROM version : 14.26T
mode :- kernal mode
Author:  digisupport [ June 28th, 2015, 12:56 ]
There is a 14.26T in the file section
http://files.hddguru.com/download/PC-30 ... arn5%204K/
Author:  shaikhmaula [ June 28th, 2015, 14:28 ]
Hi got module 11 & 13 from our group member after loading that i can see my HDD ,
but capacity it is showing 116gb when it is 500 Gb and not able to read any tracks
Saving tracks
Save Path:D:\UserDataFile\WDC Marvell\Marn5 4K\20150628-164914-00140026\Data\SABackup\Tracks\
There is an error in reading tracks:
Read Track error C/H/S: -256/0/1
Read Track error C/H/S: -256/0/2
Read Track error C/H/S: -256/0/3
Read Track error C/H/S: -256/0/4
Read Track error C/H/S: -256/0/5
Read Track error C/H/S: -256/0/6
Read Track error C/H/S: -256/0/7
Read Track error C/H/S: -256/0/8
Read Track error C/H/S: -256/0/9
