I need ROM & LDR for Diablo 3S (WD20EZRX-00D8PB0)
Posted: July 1st, 2015, 2:56
by kyriakosxn
If anybody have ROM and LOADER for Diablo 3S (WD20EZRX-00D8PB0).
I have these versions, so if you have any different version from these please reply:
00010032
00010038
0001003J
0001004Q
00010051
00010055
0001005V
0001006A
Re: I need ROM & LDR for Diablo 3S (WD20EZRX-00D8PB0)
Posted: July 1st, 2015, 5:09
by Tawfeek
0001002V
Posted: July 1st, 2015, 6:14
by Tomset
Posted: July 1st, 2015, 12:55
by Tomset
Posted: July 1st, 2015, 13:30
by kyriakosxn
Thanks man! I will test them.
Posted: July 1st, 2015, 13:43
by jermy
are you sure you're on the right track ?
because it seems to me you are trying with different ROM and LDRs and i can assume you already tried with the one that matches yours, but with no success ?!
maybe it's bad heads for example, trying with countless number of ver. doesn't gonna help.
Posted: July 1st, 2015, 14:13
by kyriakosxn
The problem in this case is that the customer damaged the original ROM chip during DIY attempt.
He tried to change PCB and transfer ROM chip to the new PCB, and now the chip is cracked . He had zero soldering-desoldering skills!!
Now I am trying to identify the original ROM version and start with LDR in order to recover native ROM!!
Posted: July 1st, 2015, 18:02
by data-medics
What I would do in a case like that is just use any old ROM + LDR from the family, read the tracks, extract the modules from the track files, find the ROM image module, and try to identify the ROM version from that.
Posted: July 1st, 2015, 18:04
by data-medics
Sometimes you find all the modules you need to rebuild the ROM that way.
Posted: July 1st, 2015, 18:13
by jermy
he PM that case closed
it appears that he tried ROMs & LDRs from same model but different heads & head map (patient 5 heads, donor 4 heads)
but the last one he got from Tomset was the match, same heads & head map (5)
Posted: July 2nd, 2015, 6:50
by kyriakosxn
Case closed thanks to ROM & LDR from Tomset!
Correct version was 0001002V with 4 heads 0 1 4 5
Thanks to everybody for the help, especially to Tomset !!
