ST3750640NS / 3.BUF / 0.EW Loader required
Posted: July 14th, 2015, 9:26
by cheadledatarecovery
Hi there, I require a loader for:
ST3750640NS
Galaxy 4D
3.BUF
S-6B
.0EW
Can anyone help? Greatly appreciated if possible,
Thanks,
John
Re: ST3750640NS / 3.BUF / 0.EW Loader required
Posted: July 14th, 2015, 10:34
by data-medics
What's the full model number and ROM version?
Posted: July 14th, 2015, 11:59
by pcimage
Sorry John,
Nothing even close :-(
Posted: July 16th, 2015, 8:25
Thanks for checking Sean & Data-Medics
The issue with this drive is that Head 1/Platter 1 is unstable. It is possible to get the drive to RDY and ID, but is not stable enough to create a LDR. I can get the drive to task in DE OK, but again the HDD is not stable enough to create a head-map via terminal/PCHS. Need to create via ATA. It is possible to read data in most LBA values but when reading after a few seconds the drive starts clicking and I get a lot of "HM" in terminal. I get the same with donor heads (below is donor I have used).
Patient
ST3750640NS
SN: 5QD.....
9BL148-045
3.BUF
WU
Donor:
ST3750640NS
SN: 5QD....
9BL148-269
3.CNK
WU
Terminal on power on:
4096k x 32 DRAM
GALAXY4D - 1_Disk S-6B 07-31-06_13:49
HM SFI
(P)SATA Reset
$HM HM HM HM HM HM HM HM HM Failed sys sect. write! Nwt Er 11 RdWr 160fa.01.0002
HM SFI
$HM HM HM HM HM HM HM HM HM Failed sys sect. write! Nwt Er 11 RdWr 160fc.01.0162
HM SFI
Posted: July 28th, 2015, 7:28
I've got this HDD more stable with a second set of heads. Just creating a LDR at the moment. On completion I'll upload, looks like a rare one.
John
Posted: July 28th, 2015, 8:21
Attached LDR
ST3750640NS P-3-BUF-5QD26W69.zip
(737.15 KiB) Downloaded 576 times
Posted: August 3rd, 2015, 12:45
Typically, 3 matching HDDs to one above have just arrived in for recovery as part of an XServe :)
