WD5000AAKX-221CA1
http://forum.hddguru.com/viewtopic.php?f=11&t=31635
Author:  walter1 [ July 23rd, 2015, 5:53 ]
Post subject:  WD5000AAKX-221CA1
Hello
someone tell me if the HDA of these disks are compatible
DCM is not the same, but date is almost the same
Thanks in advance
Author:  labtech [ July 23rd, 2015, 13:02 ]
Post subject:  Re: WD5000AAKX-221CA1
Even if the DCMs were compatible, there are chances that they may still be incompatible. There is more to the recipe.
Author:  walter1 [ July 24th, 2015, 5:28 ]
thanks to Labtech, jermy , hdd_sand
The infos of the HDDs are attached , what about?
Author:  shahij [ July 24th, 2015, 5:57 ]
They should be compatible. You can see
