ST1000DM003
http://forum.hddguru.com/viewtopic.php?f=11&t=31681
Author:  walter1 [ July 30th, 2015, 6:27 ]
Post subject:  ST1000DM003
hello
I have two disks with the same defect
ST1000DM003-CC4B date:12421 China
ST1000DM003-CC4D date:12383 China
after the spin-up the heads clicks (10 times) and then the motor stops
does not respond to commands from the terminal
can anyone help me or give me a hint?
Author:  jermy [ July 30th, 2015, 6:35 ]
Post subject:  Re: ST1000DM003
viewtopic.php?f=1&t=31665&p=219974&
Author:  pclab [ July 30th, 2015, 9:11 ]
Working on a similar case. I performed a head swap, and already got it to ID. Still some other issues tough.
So heads are the problem.
Author:  jermy [ July 30th, 2015, 10:36 ]
viewtopic.php?f=1&t=30851&p=213479#p213479
Author:  lcoughey [ July 30th, 2015, 10:53 ]
Most definitely heads, at the very least.
Author:  walter1 [ July 30th, 2015, 11:38 ]
Thanks all for your attention!!
As I thought I should look for a donor
