Hello Guru ppl
i have WD800JD-55MUA1 caviar 80 GB when connect it to pc3000 UDMA Power on 1- spin up 2- three clicks sound and spin down 3- ERR & AMN indicator = red
the HDD can auto deducted but when utility starts it give me wrong information about the model and serial and capacity (See the attached pic) the actual capacity is 80Gb and the model and serial is different
the first thing i think its head problem need to swap but when i see the wrong outcome, maybe wrong firmware or any thing else
so i stopped and asked the guru people you have diffidently a good experience
Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 2 Cyl Count............................... : 64 Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended" ROM: ROM reading............................. : Ok ROM Data size........................... : 128 Kb ROM Modules: ROM version............................. : 10.8DE ROM F/W version......................... : 108DE Overlay F/W version..................... : 10.8DE Servo F/W version....................... : 02.80 Heads configuration..................... : by map Heads number............................ : 2 Heads number in use..................... : 2 Switched off heads...................... : No Heads map............................... : 0,1 Service area: Permanent overlay....................... : Not loaded SA dir reading (ID)..................... : Unknown error code: 4343 Configuration reading................... : Module 02 not found
thanks for help
| Attachments: |
