HDD GURU FORUMS
http://forum.hddguru.com/
LDR for Pharaoh ST3500418AS please
http://forum.hddguru.com/viewtopic.php?f=11&t=31887
Page 1 of 1
Author:  Tawfeek [ September 2nd, 2015, 16:16 ]
Post subject:  LDR for Pharaoh ST3500418AS please
loader wanted for
ST3500418AS
Firmware : CC38
Author:  data-medics [ September 2nd, 2015, 17:15 ]
Post subject:  Re: LDR for Pharaoh ST3500418AS please
Here you go:
SgF3LDR.rar [174.53 KiB]
Downloaded 1085 times
Author:  Tawfeek [ September 3rd, 2015, 5:46 ]
thanks in advance data-medics. i appreciate your help
Author:  Tawfeek [ September 3rd, 2015, 5:51 ]
Update:
terminal out put
LED:000000CC FAddr:0028931D
when update microcode to SA or ram . i got error :
Test : Update microcode
Loading LOD from folder................. : F:\SgF3LDR\SgF3LDR.lod
Mode.................................... : 7
Device error detected (ABR)
ErrCode = 05269921
Result.................................. : Error
any advice here?
Author:  dodoz [ September 3rd, 2015, 9:53 ]
05269921 "Download overlay incompatible"
Version of the overlay in the loader(18.09.14-25 18/09/2009) don't match with version of your rom.
Author:  dodoz [ September 3rd, 2015, 11:57 ]
ErrCode = 05269921 - "Download overlay incompatible"
The loader contain overlay only and their version(18.09.14-25 18/09/2009) don't match with version of your rom.
Author:  Tawfeek [ September 3rd, 2015, 16:46 ]
ok what should i do ?
Author:  fzabkar [ September 3rd, 2015, 20:29 ]
Upload your ROM and hope that someone can match a loader to it?
Author:  Tawfeek [ September 5th, 2015, 7:14 ]
Thanks fzabkar
here is the Rom
ROM.rar [430.73 KiB]
Downloaded 944 times
Author:  fzabkar [ September 5th, 2015, 17:34 ]
Would it make sense to use Data-Medics' ROM and patch your own adaptives into it? Then you could use Data-Medics' loader.
Author:  fzabkar [ September 5th, 2015, 21:06 ]
I have patched a Pharaoh CC49 ROM with your adaptives and compiled a CC49 loader to suit. You may need to confirm the ROM checksum(s). Hopefully this will enable you to reach the SA and retrieve the drive's native resources.
Pharaoh_CC49_Ldr_ROM.rar [613.37 KiB]
Downloaded 942 times
Author:  Tawfeek [ September 6th, 2015, 6:25 ]
Thank you very much for your Efforts .I'll try and let you know
Author:  Tawfeek [ September 7th, 2015, 6:20 ]
Update :
* First of all thanks Mr. Frank again for your time and efforts .
* Second : I write the modified rom (CC49)with terminal but pcb is power Off. so i will Re write original Rom with programmer and strat again . any new clues over here ?
Author:  dodoz [ September 7th, 2015, 11:48 ]
Try this ; it's compatible overlay's loader for your original rom.
o_00010405.rar [174.63 KiB]
Downloaded 875 times
Author:  fzabkar [ September 7th, 2015, 12:24 ]
Maybe I was unlucky and picked a CC49 ROM where Power Up In Standby (PUIS) was enabled. If so, then the drive would have identified itself to BIOS and all that would have been required would have been to disable the PUIS using a tool such as HDAT2.
Author:  fzabkar [ September 7th, 2015, 16:29 ]
I used this CC49 firmware update ...
Barracuda 7200.12 Firmware Update (Pharaoh CC49):
http://knowledge.seagate.com/articles/e ... Q/213891en
http://www.seagate.com/staticfiles/supp ... L-CC49.iso
... and this CC49 resource dump:
http://files.hddguru.com/index.php?acti ... eagate/F3&
I patched the CC49 ROM by copying the CC38 ROM's CAP/RAP/SAP modules. The code sections of the CC49 ROM matched the corresponding code sections in the CC49 firmware update.
This is the CC38 ROM header:
00000000  F6 1D 00 00 40 00 00 00 40 00 00 00 49 C3 04 00
00000010  02 38 00 00 04 38 16 06 06 48 18 06 03 58 9C 06
00000020  0B 58 CC 07 05 58 DD 07 0E 70 FD 07 00 00 00 08
It is similar in layout to the CC49 ROM.
ID  Start  Size   Description
       00     38  header
02     38  61600  code
04  61638    210  Controller Adaptive Parameters (CAP) - serial no. / model / date
06  61848   8410  Read Adaptive Parameters (RAP)
03  69C58  13000  code
0B  7CC58   1100  code
05  7DD58   2018  Servo Adaptive Parameters (SAP)
0E  7FD70    290  size is probably only 8 bytes, remainder is FFh
These are the code sections contained in the LOD file that ships with the CC49 firmware update:
Sect Size  - Description
1     2000 -
2    12FF0 - ROM (ID 03)
3     1100 - ROM (ID 0B)
4     1100 - same as section 3
5     2000 - same as section 1
6    61638 - ROM (header + ID 02)
7     C3C0 -
8    20000 - SA OVLY (for loader)
9    30000 - SA OVLY (for loader)
10   10000 - SA OVLY (for loader)
11   10000 - SA OVLY (for loader)
I compiled a CC49 loader using sections 8 - 11.
The only thing I didn't touch was the following section of the ROM:
0007FD70  20 00 0A 00 00 00 8C 06 FF FF FF FF FF FF FF FF   PUIS enabled ?
0007FD70  20 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF   PUIS disabled ?
I suspect that the drive may have spun up if I had replaced the "20 00 0A 00 00 00 8C 06" with "20 00 00 00 00 00 00 00", but I wasn't sure about the function of this section of the ROM.
http://www.phpbb.com/
