 Post subject: DE -Select what kind of sectors to image
PostPosted: October 24th, 2015, 18:35
Hi
I've tried to find this info and couldn't get it....
In DE, how can I restart/continue to image only some kind of sectors? For instance, only getting the Read Reminder ones (the white ones) and not wanting that it tries to read the black ones in that pass.
On another pass, for instance, only try to read the yellow ones, and not the whites ones. And so on...
ACELab partner
 Post subject: Re: DE -Select what kind of sectors to image
PostPosted: October 25th, 2015, 7:02
Found it finally. :mrgreen:
ACELab partner
PostPosted: October 26th, 2015, 8:44
Hello!
I'm glad you found it on your own, maybe if you share here the solution others may find it very useful.
Best regards
PostPosted: October 26th, 2015, 10:07
Create submap based on type of sectors remained.
PostPosted: October 26th, 2015, 11:39
I Would Say PC 3000 Generally Takes 3 Months of Hard Reading To Get To Understand Approx 50% To 75% of It .What a Wast Tool It Is .
PostPosted: October 26th, 2015, 18:29
yeah, that was really that.
ACELab partner
PostPosted: October 26th, 2015, 18:31
Hi Amarbir
I saw you on almost every tool manufacturers forums, where you complain on the respective tool.
So, no tool is good for you. Or do you have one?
Why is it PC3K a waste? Because you don't know how to use it?
That's a user problem (at least for me), not a tool problem.
ACELab partner
PostPosted: October 27th, 2015, 8:44
pclab wrote:
Hi Amarbir
PCLAB ,
Its a Typo I Wanted To Say Wast Waaaasssstttt Tool [ Very Elaborate Tool ]
PS : Cannot Edit Post Now
PostPosted: October 27th, 2015, 9:34
PCLAB :D ,
I Just Released Its Called Vast Instead of Wast [Sorry English is Not My First Language ] .
