 Post subject: WDC WD5000LMVW-11CKRS0 Encripted
PostPosted: October 26th, 2015, 17:05
Hi! I have this WDC WD5000LMVW-11CKRS0, that i can clone using DE and SATA interface, but i cannot decrypt it. I cannot access to western utility cause when i try to identify it i get "HDDs RAM reading error; unexpected error: Abort command: No aditional Sense Information". I tried looking for the encription key for symwave and other encription ICs, but i guess it is a SED cause i haven t found anything.
The thing is that when i use usb interface i have exactly the same situation. I can access HDD but look encripted and i don t know why. Any clue?
 Post subject: Re: WDC WD5000LMVW-11CKRS0 Encripted
PostPosted: October 27th, 2015, 2:44
this doesn't make sense, if you use USB interface the disk should not be encrypted or am i missing something...
Data Recovery Pakistan
PostPosted: October 27th, 2015, 4:26
Could it be encrypted but another tool and not by the WD encryption chip?
Have you asked the client if he was encrypting the data?
ACELab partner
PostPosted: October 27th, 2015, 8:44
Hi MindMergepk, pclab. Thanks for your response. It doesn t make sense for me too :oops: . I have asked my client if he had used some encryption but he said that he hadn t.
What if someone changed PCB+eeprom (donnor usb PCB + original eeprom)? Could be that? I don t know why i cannot enter western utility. Have someone had same error?
Best and thanks for your help!
F
PostPosted: October 27th, 2015, 9:29
it can easily be checked out, search the ROM for the WWN (you should find it in mod 0D).
