Need Rom for SABRE53 HDD
http://forum.hddguru.com/viewtopic.php?f=11&t=32295
Author:  F_ARG [ November 11th, 2015, 8:54 ]
Post subject:  Need Rom for SABRE53 HDD
Hi All! I need a ROM for a WD400BB-xxJHA.
Version: 06AWC
SN: WCAMA104xxxx
If someone has it and want to share i will be very grateful :wink:
F
Author:  Mikippp [ November 12th, 2015, 6:02 ]
Post subject:  Re: Need Rom for SABRE53 HDD
Are you sure this version 06AWC ?
I only found 05AWC and so send in attachment
Mikippp
ROM_05AWC_01A2_BB.zip [130.72 KiB]
Downloaded 525 times
Author:  northwind [ November 12th, 2015, 6:13 ]
Checked but don't have it. Closest I have is 05BWC, so Mikki's should be closer match.
Author:  Amarbir[CDR-Labs] [ November 12th, 2015, 14:03 ]
Sir ,
Is it possible to init drive if rom + overlay mod 11 are replaced from donor same time .Also i hope not only mod 11 but other mods are also required .Just brushing up my wdc knowledge these days and slowly progressing but still doing a fab job in my area
Author:  northwind [ November 13th, 2015, 5:02 ]
Not always.
Author:  F_ARG [ November 13th, 2015, 7:34 ]
Thanks you all guys!
I will try with that Rom Mikippp an let you know.
northwind, Amarbir, I ve never done that before. But i guess i have to try it because my client is needing data ASAP :?
Best and thanks again!
F
Author:  Amarbir[CDR-Labs] [ November 13th, 2015, 7:35 ]
northwind wrote:
Not always.
Well,
I Will Remember That And Try It Out One Day And PM You Results :mrgreen:
Author:  F_ARG [ November 16th, 2015, 10:16 ]
Hi to all. I tried with eprom version you guys uploaded and tried changing firmware to the drive. None of these worked :|. When i changed fw (only overlays and some conf modules)i got ID but with ABRT error when i tried to access data. So, if someone has the matching ROM and wants to share i will be waiting with open arms. Meanwhile, i will search too :)
Best
F
