 Post subject: wd800jd-75m8a3 help
PostPosted: November 26th, 2015, 7:04
Hi!
I've got this disk and i'm trying to acces it, but i dont know SA SPT number... anyone could helpme? Thx in advance.
Maybe modules are wrong and i would like to recover it.
 Post subject: Re: wd800jd-75m8a3 help
PostPosted: November 26th, 2015, 7:07
is it spinning ?
clicking, beeping, unusual noise ?
have you tried a LDR
PostPosted: November 26th, 2015, 7:17
It tries to spinning... but head sound is present
PostPosted: November 26th, 2015, 7:38
you mean you can't hear it spinning ?
clicking ? or it sounds usual ?
PostPosted: November 26th, 2015, 7:39
cliking
PostPosted: November 26th, 2015, 7:46
probably need to replace the HSA
so... a LDR doesn't gonna help you
but if you wanna try... what's the F/W ver. ?
PostPosted: November 26th, 2015, 8:56
Firmware is 10.01E04
PostPosted: November 26th, 2015, 9:37
please ROM F/W ver. not ROM ver.
PostPosted: November 26th, 2015, 9:43
ROM version 10.9DE[
PostPosted: November 26th, 2015, 14:19
Seems like typo. Should be "MU", not "M8".
PostPosted: November 26th, 2015, 14:27
how did you come to this conclusion ?
PostPosted: November 26th, 2015, 14:43
edit: you probably right
PostPosted: November 27th, 2015, 3:12
This is the HDD
PostPosted: November 27th, 2015, 6:05
And another pic...
PostPosted: November 27th, 2015, 6:25
Its MSA and its Sabre58 and SPT is 533 - but I suspect you have some mechanical errors you need to resolve first.
PostPosted: November 28th, 2015, 8:10
Agree, if it's clicking then 99% certainly it has physical (heads) issues.
PostPosted: November 30th, 2015, 4:00
Loader is made, loaded into RAM.
Now, no errors are visible except hdd capacity... hdd capacity is wrong...
any ideas to recover it?
thx
PostPosted: November 30th, 2015, 4:19
an error is happening now STATIC MODULE READING ERROR - DEVICE ERROR DETECTED "FM ERR
NOT STATIC FILE"
cron
