 Post subject: LDR needed for WD3200BEKT-08PVMT1
PostPosted: December 4th, 2015, 11:19
I need loader & Modules for the following drive:
Everest V
WD3200BEKT-08PVMT1
ROM Modules:
ROM version............................. : 04.0EA
ROM F/W version......................... : 0004000E
Overlay F/W version..................... : 04.0EA
Servo F/W version....................... : 02.02
Heads number............................ : 2
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
D.R.L Data Revive Lab Services Ltd
Web: https://www.datarevive.net
 Post subject: Re: LDR needed for WD3200BEKT-08PVMT1
PostPosted: December 10th, 2015, 11:25
Here you are...
Mikippp
11.zip [241.34 KiB]
Downloaded 442 times
PostPosted: December 10th, 2015, 12:41
Thank you man!!!
