| FBLite LDR for 0016001C needed - WD10JMVW-11AJGS2 http://forum.hddguru.com/viewtopic.php?f=11&t=32709 |
Page 1 of 1 |
| Author: | -BR- [ January 12th, 2016, 16:55 ] |
| Post subject: | FBLite LDR for 0016001C needed - WD10JMVW-11AJGS2 |
Hi, I need LDR (and modules / tracks if possible) for the following Fblite: Model: WD10JMVW-11AJGS2 Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 4 Cyl Count............................... : 256 ROM: ROM reading............................. : Ok ROM Data size........................... : 256 Kb Flash ROM dir reading................... : Ok (Active) Flash ROM dir reading (Ext)............. : Ok Modules directory address............... : 111 275 SA regions address...................... : by default SA Translator loading................... : Ok ROM Modules: ROM version............................. : 16.56H ROM F/W version......................... : 00160056 Overlay F/W version..................... : 16.56H Servo F/W version....................... : N0.38 Heads configuration..................... : by map Heads number............................ : 4 Heads number in use..................... : 4 Switched off heads...................... : No Heads map............................... : 0,1,2,3 Thanks in advance! -BR- |
| Author: | labtech [ January 12th, 2016, 21:33 ] |
| Post subject: | Re: FBLite LDR for 0016001C needed - WD10JMVW-11AJGS2 |
Different MDL, but same family. http://files.hddguru.com/index.php?acti ... ty/Fblite& |
