 Post subject: FBLite LDR for 00160056 needed - WD10JMVW-11AJGS2
PostPosted: January 12th, 2016, 22:21
Correcting the other post title (sorry, for the TYPO) :(
I need LDR for ROM FW: 00160056
(modules and tracks also apreciated if available)
Model: WD10JMVW-11AJGS2
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 111 275
SA regions address...................... : by default
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 16.56H
ROM F/W version......................... : 00160056
Overlay F/W version..................... : 16.56H
Servo F/W version....................... : N0.38
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
Thanks again,
-BR-
 Post subject: Re: FBLite LDR for 00160056 needed - WD10JMVW-11AJGS2
PostPosted: January 13th, 2016, 4:05
Here you go
11_1B_16.56H.zip [528.59 KiB]
Downloaded 861 times
PostPosted: January 13th, 2016, 10:27
Thank you very much Arthur!
Your LDR did get me access to SA :D
But I get some bad modules.
Can you be so kind to upload some modules ?
I need:
04, 2E, 50, 51, 52 and 53
Thank you again,
-BR-
PostPosted: January 13th, 2016, 19:35
2E is no needed to access data
PostPosted: January 14th, 2016, 4:38
04 does not exist in this fw
modules.zip [4.58 KiB]
Downloaded 770 times
PostPosted: January 14th, 2016, 11:45
Case closed
Data was saved thanks to Arthur and labtech :D
Cheers,
-BR-
PostPosted: February 22nd, 2016, 12:16
-BR- wrote:
BR
Can u provide full modules backup for the said model hdd in rpm or mod?
PostPosted: February 22nd, 2016, 12:33
Here you go:
https://gofile.me/6nc9a/pMnWdx4q
PostPosted: February 23rd, 2016, 12:04
Thank you data-medics,
PostPosted: May 12th, 2017, 14:29
data-medics wrote:
+1 Jared, you save me here.
Regards.
Marcus
Users browsing this forum: No registered users and 100 guests
