 Post subject: USB to Sata Converter
PostPosted: January 18th, 2016, 13:04
I have a WD5000BMVW 500GB USB disk. No clicking sound and do not recognized on PC.
I swap ROM chip from USB PCB 771814 to SATA PCB 771820. Then connect it to PC3000 and no green lights on PC3000, seems disk is dead but I swap the ROM chip to 3 different SATA 771820 and same result.
Any idea why do not work?
Rgds,
 Post subject: Re: USB to Sata Converter
PostPosted: January 18th, 2016, 23:11
swapped physically or flashed the ROM
PostPosted: January 19th, 2016, 5:35
swapped physically
PostPosted: January 19th, 2016, 7:45
try to read the ROM with an external programmer (or any other way), and take a good working PCB and flash the ROM with a programmer or using PC3K.
PostPosted: January 20th, 2016, 4:33
+ 1 Agree.
Its either the ROM checksum doesn't pass or pre-amp.
Web: https://www.day1data.de
PostPosted: January 22nd, 2016, 5:28
Hello!
I found myself in a similar situation and it was the ROM, damaged. So i had to rebuild ROM from SA using PC3K and flash it to a donor PCB.
<Good luck
PostPosted: January 22nd, 2016, 9:27
Yeah it is ROM damaged.
AdrianSRD, was your disk a USB drive like mine? Which type of donor you choose, a match USB drive?
I was speaking with ACE Support and their solution is just for drives with internal ROM (no U12 chip). My disk has an external ROM.
Any other ideas?
PostPosted: January 22nd, 2016, 9:33
what's the DOM ?
PostPosted: January 22nd, 2016, 9:40
Do you mean DCM?
the disk is:
WD5000BMVW-11AMCS4
Date: 8 June 2012
DCM: HHOT2HN
Rgds,
PostPosted: January 23rd, 2016, 14:23
can you upload the damaged ROM ?
PostPosted: January 24th, 2016, 6:16
Rgds,
Hi ,
Have You Ruled out a Possible HSA Short ? . Do You Know How To Test that if Not i Can Teach You
PostPosted: January 24th, 2016, 14:12
It's good to share us that
Expect, the Unexpected
PostPosted: January 25th, 2016, 4:50
Hi ,
If you wanna learn ,post a new thread and pm me the link of the same i will do the needful .In this thread i will is the thread opener wants .
PostPosted: January 25th, 2016, 12:58
Amarbir, If it is a HSA Short, would the disk try to read with a good PCB from another disk (without ROM changed)? Can you please share with us how to test HSA Short?
Jermy, I can read the ROM in the TL866. File attached.
Thanks.
PostPosted: January 25th, 2016, 13:00
ROM file now attached. Please change the extension to .bin
ROM_WD5000BMVW.doc [256 KiB]
Downloaded 1415 times
PostPosted: January 25th, 2016, 14:38
Amarbir wrote:
Hi ,
Ok, Ill do as u want
PostPosted: January 25th, 2016, 15:13
The ROM looks OK.
Analysing ROM_WD5000BMVW.bin ...
Searching for LDSCs and verifying PCMBlocks ...
LDSC   LDSC    PCMBLock       PCMBlk CS
Start  ID CS   Start - End     Exp/Act
00000  5A 81   00100 - 019B1  B992 B992   OK
00020  01 59   019B2 - 03A1A    03   03   OK
00040  02 78   03A1B - 0D653    95   95   OK
00060  03 03   0D654 - 0DB08    17   17   OK
00080  04 93   0DB09 - 0DD69    77   77   OK
000A0  05 28   0DD6A - 0DF8A    B9   B9   OK
000C0  06 59   0DF8B - 2AC07    59   59   OK
000E0  07 CF   2AC08 - 3DF88    D3   D3   OK
LDSC   = PM Loader Config String (32 bytes)
ID     = ID byte of LDSC (byte #0)
CS     = Checksum byte or word
PCMBlk = Program Code Memory Block
Exp    = Expected checksum for PCMBLock
Act    = Actual checksum for PCMBLock
4F.BIN: 1024 bytes      checksum32 = 0x00000000
47.BIN: 1024 bytes      checksum32 = 0x00000000
0D.BIN: 144 bytes       checksum32 = 0x00000000
30.BIN: 1024 bytes      checksum32 = 0x00000000
0B.BIN: 336 bytes       checksum32 = 0x00000000
0A.BIN: 64 bytes        checksum32 = 0x00000000
If you want to test for a shorted preamp, upload detailed photos of both sides of your PCB.
PostPosted: January 26th, 2016, 12:45
Thanks fzabkar,
Here are the PCB photos. The ROM is not on the photo as I took it out to read in TL866.
PostPosted: January 26th, 2016, 15:35
Can you measure the voltages between ground (any screw hole) and each of the 18 pins at the HDA connector on the PCB?
PostPosted: January 27th, 2016, 11:28
Just measure the voltage as suggested and I got value between 0.13V to 0V.
What should be the expected values?
What are we testing here?
Rgds,
