| WD Esprit LDR needed 00090030 http://forum.hddguru.com/viewtopic.php?f=11&t=32885 |
Page 1 of 1 |
| Author: | pcimage [ February 10th, 2016, 7:46 ] |
| Post subject: | WD Esprit LDR needed 00090030 |
WD5000BPKT-00PK4T0... Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 3 Cyl Count............................... : 256 ROM: Read ROM................................ : Ok ROM Data size........................... : 512 Kb Flash ROM dir reading................... : Ok SA regions address...................... : by default SA Translator loading................... : Ok ROM Modules: ROM version............................. : 09.30D ROM F/W version......................... : 00090030 Overlay F/W version..................... : 09.30D Servo F/W version....................... : SM.1V Heads configuration..................... : by map Heads number............................ : 4 Heads number in use..................... : 3 Switched off heads...................... : Yes Heads map............................... : 0,2,3 Cheers! |
| Author: | microsoftengineer [ February 10th, 2016, 8:05 ] |
| Post subject: | Re: WD Esprit LDR needed 00090030 |
here it is ....... http://files.hddguru.com/index.php?acti ... ty/Esprit& |
| Author: | pcimage [ February 10th, 2016, 13:40 ] |
Thanks guys. I have the LDR now, but it seems this drive has more serious issues too |
| Author: | unknown [ February 10th, 2016, 13:48 ] |
Scratches to the surface or similar? |
| Author: | pcimage [ February 10th, 2016, 14:43 ] |
unknown wrote: Scratches to the surface or similar? Don't think so, sounds pretty normal and platters look in good shape and no bent heads. But either the heads are suspect/weak or the SA is pretty unhealthy, awaiting client approval of costs before proceeding any further..... |
| Author: | unknown [ February 10th, 2016, 16:08 ] |
Got it. Good luck Mr. Sean. |
