| LDR for WD2500AAJB-00WGA0 http://forum.hddguru.com/viewtopic.php?f=11&t=32964 |
Page 1 of 1 |
| Author: | outbreak198x [ February 23rd, 2016, 13:07 ] |
| Post subject: | LDR for WD2500AAJB-00WGA0 |
Hello, anyone out there having such a LDR? :=) ROM FW is 005800AA - Firmware i can not read out. I think it's head damage (Because also scratches on disk) - but i'll try - with Files from database (it's not compatible) |
| Author: | outbreak198x [ February 23rd, 2016, 13:25 ] |
| Post subject: | Re: LDR for WD2500AAJB-00WGA0 |
FW should be 58.AAD Headmap is 0,1,2. maybe also someone having such a disk and can send it with Express? |
| Author: | jermy [ February 23rd, 2016, 13:32 ] |
outbreak198x wrote: Headmap is 0,1,2. you sure ? here is written otherwise, 0,1,3 outbreak198x wrote: maybe also someone having such a disk and can send it with Express? they can provide you a LDR (and resources) and they will ship it to you too |
| Author: | Tomset [ February 23rd, 2016, 13:35 ] |
Are: WD2500AAJB-00WGA0-00.02C01-(58.AAD)-WCARY WD2500AAJB-00WGA0-58.01H58-(58.AAH)-WCAS2 |
| Author: | outbreak198x [ February 23rd, 2016, 14:43 ] |
Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 3 Cyl Count............................... : 128 ROM: Read ROM................................ : Ok ROM Data size........................... : 192 Kb Flash ROM dir reading................... : Ok SA regions address...................... : by default SA Translator loading................... : Ok SA defects assigned..................... : 1 ROM Modules: ROM version............................. : 58.AAD ROM F/W version......................... : 005800AA Overlay F/W version..................... : 58.AAD Servo F/W version....................... : 01.0L Heads configuration..................... : by map Heads number............................ : 3 Heads number in use..................... : 3 Switched off heads...................... : No Heads map............................... : 0,1,2 OK thx now i found it :=) but think it's dead... |
| Author: | Tomset [ February 23rd, 2016, 14:50 ] |
http://files.hddguru.com/download/PC-30 ... 959215.rar |
| Author: | outbreak198x [ February 23rd, 2016, 15:46 ] |
Great thx, i booted up set 0 2 2 in RAM MAP - so it spins loaded LDR, read out modules, reboot, load again 0 2 2 otherwise not possible, loaded my LDR . read out data from h0 nearly 100%, now i've to come near headcrash |
