HDD GURU FORUMS
http://forum.hddguru.com/
Wrong SN and LBA
http://forum.hddguru.com/viewtopic.php?f=11&t=32977
Page 1 of 1
Author:  LostDataSa [ February 25th, 2016, 10:06 ]
Post subject:  Wrong SN and LBA
hi i have WD 1TB, the drive spin fine but i get these
Model : WDC WD10EZRX-00A8LB0
Serial : WDC-ROM SN# XYZ----
Firmware : 01.01A01
Capacity : MB (1)
the model is correct
when i choose Utility Statues I get the correct info also when choosing "Edit HDD ID" i get the correct SN and LBA.
What seems to be the problem ?
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 256
Zone allocation table................... : Ok
SA SPT.................................. : 1682
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 93 026
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 65.18J
ROM F/W version......................... : 00650018
Overlay F/W version..................... : 65.19J
Servo F/W version....................... : 38.02
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
Service area:
Permanent overlay....................... : Loaded
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
HDD ID reading.......................... : Ok
Heads test
Cylinder to test........................ : -10
Heads to test........................... : 0,1
Head 0.................................. : Ok
Head 1.................................. : OK
Author:  northwind [ February 25th, 2016, 11:06 ]
Post subject:  Re: Wrong SN and LBA
Mod02?
Modules OK?
Author:  pcimage [ February 25th, 2016, 17:12 ]
Show results of SA module check
Author:  LostDataSa [ February 26th, 2016, 7:57 ]
109
FA
6F
6A
69
43
12
04
These models are bad
Author:  pcimage [ February 26th, 2016, 8:12 ]
Try and read the mods by composite read, to see if you can get one good copy.
Most of those mods aren't important.
Author:  LostDataSa [ February 27th, 2016, 8:51 ]
i found a donor HDA and i replaced all dead models and it works fin now
thank you all
Author:  jermy [ February 27th, 2016, 14:16 ]
you copied mod 43 from donor to patient ?
http://www.phpbb.com/
