 Post subject: Help!!! WD400- WD400BB-75EA0 - PC3K can not access it yet
PostPosted: April 29th, 2016, 23:06
Help... Need your guidance.
HDD western digital WD400- WD400BB-75EA0
Start spinning and HDD is making high trebele sound.
I am getting this error as soon as I run autodetect or run utility.
Error:
1. PIO Register Access TimeOut
2. HDD Readyness Timeout (10000)
3. Techno key error
Attached pictures.
Thank you for the guidance.
Best Regards,
File comment: error trying autodetect
File comment: error trying autodetect or run utility
 Post subject: Re: Help!!! WD400- WD400BB-75EA0 - PC3K can not access it ye
PostPosted: April 30th, 2016, 0:23
It is showing Drive is not ready and did a research on forum and people is saying it might be translator issue ending in PCB problem.
Since is not accessible yet as it is I can not do some tips AceLab suggested.
some pictures attached of errors
PostPosted: April 30th, 2016, 3:38
Have you put the jumper in place?
Instead of drd dsc all registers will flash as per your 3rd pic, if you didn't.
Also why are you trying to SS the drive? :o
PostPosted: April 30th, 2016, 5:28
make sure jumper settings on the hard drive is master
PostPosted: April 30th, 2016, 9:18
Tell us more about the sound the drive makes as mentioned in your first post. Is it a high pitched 'ringing' sound. Can you post a recording?
PostPosted: April 30th, 2016, 10:48
In WD drives, all jumpers off are required for master.
If it's making noises, the heads could be making contact with the platters. Be very careful.
Can you get access to firmware modules? If so, start by reading the firmware modules into the PC-3000. Then you need to determine which firmware modules are damaged.
If you don't have access to firmware then you may need to put the hard drive in safe mode and turn all heads off except head 0 in RAM in order for you to get access to the firmware. If that does not work, you can try eliminating all heads except head 1. Again, once you gain access to the firmware, you will need to read all copies of the firmware into the PC-3000 and determine which ones are damaged. You may end up needing a very close match donor drive that will allow you to perform hot swap / smart hot swap to gain access to data.
PostPosted: April 30th, 2016, 11:00
Welcome to the forum Mr J :-)
PostPosted: May 3rd, 2016, 21:26
You guys rock.
I was able to put the jumpers and able to recovered the data.
You guys rock again.
Thank you a lot for your time.
Best regards,
PostPosted: May 4th, 2016, 0:07
DDrecovery ,
Is This jol ?
PostPosted: May 4th, 2016, 12:44
Amarbir[CDR-Labs] wrote:
DDrecovery ,
Is This jol ?
Hey Amarbir, no its another person.
Users browsing this forum: No registered users and 100 guests
