 Post subject: ***PC3K: Data Copied is less than what it shows as copied***
PostPosted: May 6th, 2016, 4:34
Need help.
Data extractor shows is copying the whole data stored but when I go to check it is only 10%. why? loss readiness is 9 from 66 055 239
Please help.
Best regards,
File comment: Attached shows copied 31.5 GB but when I go to the HDD is showing only 4GB
 Post subject: Re: ***PC3K: Data Copied is less than what it shows as copie
PostPosted: May 6th, 2016, 7:09
Compare drive capacity and drive model, they are not corresponding each to other. Looks like your drive is truncated to 32 GB, by jumpers or by HPA/DCO, it should be 78142168 LBA's (~ 37GB), but you have 66 millions (~ 32 GB). Check in utility drive confiuration and turn drive to normal capacity.
