 Post subject: Need LDR + modules for WD3200AAJS-00B4A0 ROM F/W 000500BR
PostPosted: June 10th, 2016, 17:31
Hello all.
Need modules and LDR for WD3200AAJS-00B4A0 ROM F/W 000500BR
ROM Modules:
ROM version............................. : 05.BRE
ROM F/W version......................... : 000500BR
Overlay F/W version..................... : 05.BRE
Servo F/W version....................... : 04.AL
Thank you all in advance!
-BR-
 Post subject: Re: Need LDR + modules for WD3200AAJS-00B4A0 ROM F/W 000500B
PostPosted: June 10th, 2016, 18:22
In the files section since 2011....
PostPosted: June 11th, 2016, 12:07
Thank you for trying to help!
I always try the files section prior to asking.
Are you referring to the file uploaded by Yustik on 30 May 2011 ?
http://files.hddguru.com/download/PC-3000-UDMA%20Support/WDC%20Marvell%20family%20utility/Pinnacle/
http://files.hddguru.com/download/PC-3000-UDMA%20Support/WDC%20Marvell%20family%20utility/Pinnacle/WDC%20WD2500AAJS-00B4A0%2001.03A01%20WD-WCAT19724283.pcr
It won´t import on my UDMA database 5.7.x or 6.x :(
It shows
Import complete:
- Added: 0
- Copied: 0
- Skipped: 0
I believe that because of the old data the file might be in an older format.
If you can import this .PCR can you please post a new file compatible with the latest UDMA database?
I´m still looking for LDR + modules from this ROM FW version
Thank you again,
-BR-
PostPosted: June 11th, 2016, 17:39
viewtopic.php?t=32469&p=234741#p234741
