| ST3000DM001 Help http://forum.hddguru.com/viewtopic.php?f=11&t=33626 |
Page 1 of 1 |
| Author: | hyuce [ June 15th, 2016, 14:28 ] |
| Post subject: | ST3000DM001 Help |
Hello Folks, My patient drive ST3000DM001. First problem was No ID and access terminal. i solved that issue and drive worked. When i started to clone Head1 was weak. Disabled it and contunie to cloning. When cloning process at %40 i cant read any sector at udma mode. But i can read with utility but very slowly. i head swaped and worked well, i started clone again with udma mode. maybe 2 hours later i havent read any sectors again. But still read sectors with utility as slowly. cleared the smart. nothing changed. tried translator regen still same. edit id unchecked all box, still same. i had no success for recover translator. i wanna show the log.. i need any advice please. Thanks HDD family detecting... Family ID: 58 Selected family......................... : 58, Grenada Model by ID............................. : ST3000DM001-1CH166 Loading default settings! Use the options dialog to review and save utility settings. Then press OK! Family default settings loading! Tech Key... Requesting FW Pkg ver ........ GPX17D.CCD2.DC0CAL.CC29 Detecting Phys Sct Size... Result.................................. : 4096 Detecting Max Head number... Phys. heads............................. : 6 Obtaining Saved Mode Pages File information... Reading Saved Mode Pages... Parsing Saved Mode Pages... LBA alignment........................... : 0 Obtaining Registry File information... Reading Registry File... Parsing Registry File... Media Cache =========== MC : disabled MC Size : 0x43FFA0 MCMT Ver : MCMTV05 Collecting Sys Files information... ID Len =============== 0 36 Reserved Defect Table (SA defect table) 1 2 Drive Information File (DIF) 2 16 Performance Parameter File (PPF) 3 7782 Primary Defect File (P-List)) 5 4 Manufacturing Information File (MIF) 8 4800 B 1000 C 122880 Serial Port Test Results File (Self Scan Log) D 160 E 432 Data Integrity Check (DIC), HEAD 0 F 223 DIC Dummy File 13 8 Disc Registry File (settings, security, etc) 15 100 BGMS File (Directed Offline Scan) 16 2 17 40 19 24 Log File 1A 33 Log File 1B 1 Log File 1C 9 1D 128 Physical Overlay File 0 1E 128 Physical Overlay File 1 22 80 Drive Self Test (DST), Head 0 23 80 Drive Self Test (DST), Head 1 24 80 Drive Self Test (DST), Head 2 25 80 Drive Self Test (DST), Head 3 26 80 Drive Self Test (DST), Head 4 27 80 Drive Self Test (DST), Head 5 2A 9 Saved Mode Pages (HDD settings) 2B 10118 R/W Operating Parameters (translator, etc) 2C 432 Data Integrity Check (DIC), HEAD 1 2D 432 Data Integrity Check (DIC), HEAD 2 2E 432 Data Integrity Check (DIC), HEAD 3 2F 432 Data Integrity Check (DIC), HEAD 4 30 432 Data Integrity Check (DIC), HEAD 5 33 4576 34 640 Packed CONGEN XML definition 39 8192 3A 4 3D 3072 3E 3072 3F 4576 40 7 41 2180 42 4096 43 10241 44 1939440 45 808580 46 226172 47 226172 48 226172 49 226172 4A 226172 4B 8192 4F 14336 51 18432 52 1024 53 8192 54 3984384 Collecting Sys File Infos completed Collecting DT Infos... ROM: ID MemOffs Len =========================== 0 40030200 40944 Read Adaptive Parameters File (RAP) 1 40030000 512 Controller Adaptive Parameters File (CAP) 4 1D400 7168 Servo Adaptive Parameter File (SAP) 40002000 13288 total 20456 5 6C000 81920 Servo Firmware Table A 25EA50 1024 Seek Profile 13 401393F8 1440 Dependent Zone Table for User Area 14 40139998 120 Dependent Zone Table for System Area 15 0 524288 Flash ROM 1D 40030220 424 VBAR Configuration File 1E 400305B8 4016 Zone Format Parameters File 26 40136F28 9424 27 40136D30 504 RAM: ID MemOffs Len =========================== 0 40030200 40944 Read Adaptive Parameters File (RAP) 1 40030000 512 Controller Adaptive Parameters File (CAP) 2 400303C8 496 Zone Table 4 1D400 7168 Servo Adaptive Parameter File (SAP) 40002000 13288 total 20456 5 6C000 81920 Servo Firmware Table 6 1915C40 81964 Servo Flaw Table A 25EA50 1024 Seek Profile 13 401393F8 1440 Dependent Zone Table for User Area 14 40139998 120 Dependent Zone Table for System Area 15 0 524288 Flash ROM 16 40030200 32 Drive Configuration Table 17 400319A0 2016 Temperature Control Configuration 1D 40030220 424 VBAR Configuration File 1E 400305B8 4016 Zone Format Parameters File 1F 4032C8E8 4500 RW working user preamp table 20 4032DA80 150 RW working system preamp table 26 40136F28 9424 27 40136D30 504 Collecting DT Infos completed Reading autotuning buffer............... Ok Searching module table in RAM... ....... Ok Searching volume 3 file table in RAM.... Ok Searching volume 0 file table in RAM.... Ok Searching SMP RAM FID in RAM............ Ok Searching Non Resident G-List FID in RAM Ok Searching CFW OVL FID in RAM............ Ok Searching DT table(RAM, WR) in RAM...... Ok Searching DT table(RAM, RD) in RAM...... Ok System Files I/O method detection... ATA(direct) Test : Reading modules Reading modules to profile folder Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Grenada\ST3000DM001-1CH166-CC29-Z1F4FMQ2\Data\ModDir\ Module 0000, Reserved Defect Table (SA defect table).................. : Ok Module 0001, Drive Information File (DIF)............................. : Ok Module 0002, Performance Parameter File (PPF)......................... : Ok Module 0003, Primary Defect File (P-List))............................ : Ok Module 0005, Manufacturing Information File (MIF)..................... : Ok Module 0008........................................................... : Ok Module 000B........................................................... : Ok Module 000C, Serial Port Test Results File (Self Scan Log)............ : Ok Module 000D........................................................... : Ok Module 000E, Data Integrity Check (DIC), HEAD 0....................... : Ok Module 000F, DIC Dummy File........................................... : Ok Module 0013, Disc Registry File (settings, security, etc)............. : Ok Module 0015, BGMS File (Directed Offline Scan)........................ : Ok Module 0016........................................................... : Ok Module 0017........................................................... : Ok Module 0019, Log File................................................. : Ok Module 001A, Log File................................................. : Ok Module 001B, Log File................................................. : Ok Module 001C........................................................... : Ok Module 001D, Physical Overlay File 0.................................. : Ok Module 001E, Physical Overlay File 1.................................. : Ok Module 0022, Drive Self Test (DST), Head 0............................ : Ok Module 0023, Drive Self Test (DST), Head 1............................ : Ok Module 0024, Drive Self Test (DST), Head 2............................ : Ok Module 0025, Drive Self Test (DST), Head 3............................ : Ok Module 0026, Drive Self Test (DST), Head 4............................ : Ok Module 0027, Drive Self Test (DST), Head 5............................ : Ok Module 002A, Saved Mode Pages (HDD settings).......................... : Ok Module 002B, R/W Operating Parameters (translator, etc)............... : Ok Module 002C, Data Integrity Check (DIC), HEAD 1....................... : Ok Module 002D, Data Integrity Check (DIC), HEAD 2....................... : Ok Module 002E, Data Integrity Check (DIC), HEAD 3....................... : Ok Module 002F, Data Integrity Check (DIC), HEAD 4....................... : Ok Module 0030, Data Integrity Check (DIC), HEAD 5....................... : Ok Module 0033........................................................... : Ok Module 0034, Packed CONGEN XML definition............................. : Ok Module 0039........................................................... : Ok Module 003A........................................................... : Ok Module 003D........................................................... : Ok Module 003E........................................................... : Ok Module 003F........................................................... : Ok Module 0040........................................................... : Ok Module 0041........................................................... : Ok Module 0042........................................................... : Ok Module 0043........................................................... : Ok Module 0044........................................................... : Error Error : Out of memory Modules reading process completed Test : Reading modules Test : DT reading Reading DT to profile folder Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Grenada\ST3000DM001-1CH166-CC29-Z1F4FMQ2\Data\CPDir\ DT 0000 (Flash ROM), Read Adaptive Parameters File (RAP).............. : Error Error : Rq Rd DT part ID 0, Offs 0x0 err! Tech state 0x72, 0x05260207 DT 0001 (Flash ROM), Controller Adaptive Parameters File (CAP)........ : Ok DT 0004 (Flash ROM), Servo Adaptive Parameter File (SAP).............. : Error Error : Rq Rd DT part ID 4, Offs 0x0 err! Tech state 0x72, 0x05260207 DT 0005 (Flash ROM), Servo Firmware Table............................. : Ok DT 000A (Flash ROM), Seek Profile..................................... : Ok DT 0013 (Flash ROM), Dependent Zone Table for User Area............... : Ok DT 0014 (Flash ROM), Dependent Zone Table for System Area............. : Ok DT 0015 (Flash ROM), Flash ROM........................................ : Ok DT 001D (Flash ROM), VBAR Configuration File.......................... : Ok DT 001E (Flash ROM), Zone Format Parameters File...................... : Ok DT 0026 (Flash ROM)................................................... : Ok DT 0027 (Flash ROM)................................................... : Ok DT 0000 (RAM), Read Adaptive Parameters File (RAP).................... : Ok DT 0001 (RAM), Controller Adaptive Parameters File (CAP).............. : Ok DT 0002 (RAM), Zone Table............................................. : Ok DT 0004 (RAM), Servo Adaptive Parameter File (SAP).................... : Ok DT 0005 (RAM), Servo Firmware Table................................... : Ok DT 0006 (RAM), Servo Flaw Table....................................... : Ok DT 000A (RAM), Seek Profile........................................... : Ok DT 0013 (RAM), Dependent Zone Table for User Area..................... : Ok DT 0014 (RAM), Dependent Zone Table for System Area................... : Ok DT 0015 (RAM), Flash ROM.............................................. : Ok DT 0016 (RAM), Drive Configuration Table.............................. : Ok DT 0017 (RAM), Temperature Control Configuration...................... : Ok DT 001D (RAM), VBAR Configuration File................................ : Ok DT 001E (RAM), Zone Format Parameters File............................ : Ok DT 001F (RAM), RW working user preamp table........................... : Ok DT 0020 (RAM), RW working system preamp table......................... : Ok DT 0026 (RAM)......................................................... : Ok DT 0027 (RAM)......................................................... : Ok DT reading process completed |
| Author: | digisupport [ June 15th, 2016, 15:10 ] |
| Post subject: | Re: ST3000DM001 Help |
Tell us how you "solved" no ID and terminal, i think that will give us some hints in the right direction. Most likely you have translator issues, but how to fix - depends on what you have done. |
| Author: | hyuce [ June 15th, 2016, 16:33 ] |
Yes i thought drive has got a translator issue. i recovered translator and cloning with success at now. i solved this wa: when no id and terminal access. Power on/off many times and press ctr+r command. its worked for me. |
