 Post subject: Logical Test vs. Sector Edit
PostPosted: July 4th, 2016, 16:02
I have currently a problem with a Seagate ST3000DM001 HDD. The good thing is, that I have the data from the HDD, the bad thing is, that I have some kind of problem with PC-3000. After I get the data from the HDD without a single bad block, I run a "Logic Scan" test. After a few blocks, I got many
"ERROR! LBA : 430 614 394 DMA Ext Reading error HDD DMA RQ timeout (30)"
Errors. But when I open the LBA in Sector Edit, I can read the data of the LBA. So what's wrong?
 Post subject: Re: Logical Test vs. Sector Edit
PostPosted: July 4th, 2016, 17:35
You working on the source (patient) drive ?
