| Logical Test vs. Sector Edit http://forum.hddguru.com/viewtopic.php?f=11&t=33727 |
Page 1 of 1 |
| Author: | D_R [ July 4th, 2016, 16:02 ] |
| Post subject: | Logical Test vs. Sector Edit |
Hi, I have currently a problem with a Seagate ST3000DM001 HDD. The good thing is, that I have the data from the HDD, the bad thing is, that I have some kind of problem with PC-3000. After I get the data from the HDD without a single bad block, I run a "Logic Scan" test. After a few blocks, I got many "ERROR! LBA : 430 614 394 DMA Ext Reading error HDD DMA RQ timeout (30)" Errors. But when I open the LBA in Sector Edit, I can read the data of the LBA. So what's wrong? |
| Author: | jermy [ July 4th, 2016, 17:35 ] |
| Post subject: | Re: Logical Test vs. Sector Edit |
You working on the source (patient) drive ? |
