| WD5000LMVW SED DRIVE LOCKED http://forum.hddguru.com/viewtopic.php?f=11&t=33732 |
Page 1 of 1 |
| Author: | livetheenergy [ July 5th, 2016, 10:25 ] |
| Post subject: | WD5000LMVW SED DRIVE LOCKED |
Hi gurus, anyone know how to fix a SED DRIVE LOCKED DRIVE ? ![]() Thanks to everyone |
| Author: | pcimage [ July 5th, 2016, 10:41 ] |
| Post subject: | Re: WD5000LMVW SED DRIVE LOCKED |
PC3000 can do it if you have a recent version. http://forum.acelaboratory.com/viewtopi ... 155&t=8555 |
| Author: | livetheenergy [ July 5th, 2016, 11:37 ] |
Thanks for this quick reply, anyway i have some problem with Load DIR in RAM, this phase fails: Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 2 Cyl Count............................... : 256 ROM: Read ROM................................ : Ok ROM Data size........................... : 256 Kb Flash ROM dir reading................... : Ok (Active) Flash ROM dir reading (Ext)............. : Ok Modules directory address............... : 62 577 SA regions address...................... : shifted SA Translator loading................... : Ok ROM Modules: ROM version............................. : 02.4CN ROM F/W version......................... : 0002004C Overlay F/W version..................... : 02.4CN Servo F/W version....................... : 02.10 Heads configuration..................... : by map Heads number............................ : 2 Heads number in use..................... : 2 Switched off heads...................... : No Heads map............................... : 0,1 Module (0001) read error Module ID 01 reading error Data request error - Device Error Detected: "Unknown error code: 51AD" This drive reads some sectors but this is very slow and do many badsectors on reading, i cannot do the headmap because the utility show this SED error in RAM. Any ideas? |
| Author: | livetheenergy [ July 5th, 2016, 12:01 ] |
I don't know how, but suddenly works, i can't figure why... anyway thank you pcimage!!! |
