HDD GURU FORUMS
http://forum.hddguru.com/
WD External Drive
http://forum.hddguru.com/viewtopic.php?f=11&t=33772
Page 1 of 1
Author:  olinyer [ July 13th, 2016, 2:23 ]
Post subject:  WD External Drive
I hope you are doing great.
What would be the best way to communicate this drive with PC3000.
This drive has a embedded USB connection to the drive and it does not have a SATA connection or any other, but, it has a connection of 12 pins in one side and 2 in other.
Connected through USB gives IO errors.
Attached picture of connections.
Thank you for the help.
Best regards,
Author:  thatdellguy [ July 13th, 2016, 2:25 ]
Post subject:  Re: WD External Drive
Discussed in lengthy detail on the Acelabs forum...
Author:  jermy [ July 13th, 2016, 3:22 ]
You can replace the PCB to sata or use WDC Marvell USB/COM
have you replaced the HSA already ?
Author:  olinyer [ July 15th, 2016, 3:38 ]
No, I have not replaced HSA.
AceLabs recommended me to connect a SATA connector as the drive is USB 3.0
http://www.phpbb.com/
