| SATA Drive with Deleted Info http://forum.hddguru.com/viewtopic.php?f=11&t=33790 |
Page 1 of 1 |
| Author: | olinyer [ July 15th, 2016, 17:40 ] |
| Post subject: | SATA Drive with Deleted Info |
Hi, I hope you are doing great. I have a SATA HDD with deleted info by a software customer used. I used PC3000 to do a partition analysis and show deleted objects and it is not showing the deleted info. Any suggestion? I was advised to used R-Studio, but i do not have it available yet so I wanted to know if there is anything I can do with PC3000 before trying R-Studio. Thank you for the help. Best regards, |
| Author: | ddrecovery [ July 15th, 2016, 17:42 ] |
| Post subject: | Re: SATA Drive with Deleted Info |
What file system is it? You can also use the R-Studio demo version to see if you can recover the files before buying. |
| Author: | fzabkar [ July 15th, 2016, 17:51 ] |
You can use PhotoRec freeware to search for specific file types. |
| Author: | olinyer [ July 20th, 2016, 14:54 ] |
Thank you for the help. It is a ".gsm" it was a recording. I saw the messages too late as I was in a hurry and I bought the R-Studio expecting I am going to use it in the future for RAIDs and others needs. It was not available, well I found something like the file but it was 0 KB, so, looks like i just found the location where it was. Thank you for your time. Best regards, |
| Author: | fzabkar [ July 20th, 2016, 16:06 ] |
If you have a good GSM file, or if you can create one, then examine its header for a signature. Then search for this signature on your drive. |
