 Post subject: PC-3K What is LDR??
PostPosted: August 13th, 2016, 3:59
HI
Everyone.
I,m PC-3K newbie... What is LDR Definite?
when does it use???
please....Sir..
 Post subject: Re: PC-3K What is LDR??
PostPosted: August 13th, 2016, 16:05
LDR is Loader. Overlay and important modules.
PostPosted: August 14th, 2016, 3:32
Mrsi wrote:
HI
Everyone.
when does it use???
please....Sir..
Loader: you may call it the 1st. BRIDGE to access the Service Area and then the Data
PostPosted: August 14th, 2016, 11:26
To add to what's already been said, it includes the ATA command set which the drive uses to communicate with the computer (or PC-3000 in this case). If the LDR doesn't load, then there's very little communication that can even happen between the PC-3000 and the drive. So it's common especially with WD drives that have SA damage that you might need to upload the LDR (module 11) so you can attempt to access and repair the service area.
PostPosted: August 15th, 2016, 21:53
pikus_09
Thank you for your answer.
PostPosted: August 15th, 2016, 22:07
data-medics,
Dear. data-medics
thank you for relying....It has been fully described .
Have a nice day.
PostPosted: August 15th, 2016, 22:10
oops.... thank you einstein9 too.
PostPosted: August 15th, 2016, 22:14
PostPosted: August 15th, 2016, 22:28
Dear. data-medics
Have a nice day.
