HDD GURU FORUMS
http://forum.hddguru.com/
Help!!! Seagate Partition Not Showing the Data
http://forum.hddguru.com/viewtopic.php?f=11&t=33933
Page 1 of 1
Author:  olinyer [ August 9th, 2016, 23:53 ]
Post subject:  Help!!! Seagate Partition Not Showing the Data
I hope you are doing great.
The HDD shows a partition but when trying to access the data is not available.
I am checking with PC3000 under the tree and when I double click the partition I can not access the data. If I select the partition shows the size of data available but I when i try to access the data it wont appear what it is inside.
Customer is experience the same, he sees there is data and it is showing the size of data but when he tries to access the data it wont let him.
Please help with any suggestions I can try.
Thank you for the help.
Best regards,
Author:  olinyer [ August 10th, 2016, 0:17 ]
Post subject:  Re: Help!!! Seagate Partition Not Showing the Data
picture attached
Author:  olinyer [ August 10th, 2016, 0:20 ]
it is like I can see the sectors and size but i can not access the data
Author:  olinyer [ August 10th, 2016, 0:37 ]
adding picture
Author:  jermy [ August 10th, 2016, 4:46 ]
Can we see a file in HEX ?
Author:  DataWreck [ August 10th, 2016, 6:51 ]
Maybe change the sector size? 2048 or something perhaps?
Author:  olinyer [ August 10th, 2016, 8:12 ]
i ran a raw recovery and it found info but i am not able to save it
Author:  olinyer [ August 10th, 2016, 8:28 ]
i tried to save a Word file and this is what it is in the file
Author:  labtech [ August 10th, 2016, 8:42 ]
Should always check and confirm with another tool.
For your case, UFS is likely best.
If the drive is degraded, create image first.
Author:  lcoughey [ August 10th, 2016, 9:53 ]
Send me a PM if you'd like some remote assistance.
Author:  olinyer [ August 10th, 2016, 23:45 ]
Yes, please, it would be great if you can help me... not sure what is PM... but yes please help...
I have used R-STUDIO and UFS and the same result... it sees there is 350GB but when i try to access the data it wont show up.
I ran RAW Recovery and it wont save the data and the files saved showed numbers with letters and excel files wont open.
My email: sk8olinyer@hotmail.com
Best regards,
Yes, please.
Author:  olinyer [ August 10th, 2016, 23:54 ]
lcoughey, yes, please.
http://www.phpbb.com/
