PC3000 DEViewer Guide or Tutorial
http://forum.hddguru.com/viewtopic.php?f=11&t=33990
Author:  labtech [ August 16th, 2016, 20:26 ]
Post subject:  PC3000 DEViewer Guide or Tutorial
Many probably have already created one, but here is a tutorial if needed.
DEViewer Tutorial.pdf [392.1 KiB]
Downloaded 1022 times
Author:  northwind [ August 17th, 2016, 4:35 ]
Post subject:  Re: PC3000 DEViewer Guide or Tutorial
There is a problem in properly creating the .acerep files. It will contain all files and there is no way to leave outside files with bad sectors etc.
We have informed Ace about this issue.
Author:  lcoughey [ August 17th, 2016, 7:24 ]
I've been asking them for a couple years to be able to filter selection based on file recoverability, but nothing thus far.
Author:  labtech [ August 17th, 2016, 8:43 ]
Thanks, good to know... at times it does not look like it does what it should.
I actually went ahead and used it this time just because of a client whose drive is crappy. Tried to get them to tell us critical files, but it is imperative they have to see folder/file structure first. Likely comparing to stuff they have already backed up.
Oh well, c'est la vie.
Author:  labtech [ August 17th, 2016, 8:44 ]
Ala Deepspar? Think they do that right in DRE, right?
Author:  jermy [ August 17th, 2016, 8:49 ]
Yes but supports only FAT and NTFS MBR based
Author:  labtech [ August 17th, 2016, 8:50 ]
Sucks, but still better than nothing.
Author:  lcoughey [ August 17th, 2016, 10:34 ]
FAT, NTFS, HFS+ and EXT, the most common of the file structures.
I have found three ways to show clients good and bad files.
1. Generate a file report with DE as a CSV, convert to XLS, filter results based on good and damaged files. Although this works, the presentation of an XLS file sucks and is very difficult for a client to work through when they have millions of files.
2. Fully recover the data out, filtering the damaged files into a folder called 'Damaged' (default is !Problem). Then copy the good files into a folder called 'Good'. Then, use snap2html to generate a file listing showing both the good and damaged folders with a searchable file structure
3. Export the map to DDI and use DRE to generate a file report
Although DE has improved over the past few years, it seems that such feature requests are low on the developer's scale of priority.
Author:  jermy [ August 17th, 2016, 11:42 ]
Method 2 is too much time
Author:  einstein9 [ August 17th, 2016, 12:30 ]
for some reason Am using this Attached freeware App.
where you can send it to your client and Open the File which you already made with it.
Client selects/Deselects whatever he wants and you move on.
very easy, and Thanx to the Author.
FDV_FOR end USERS.rar [140.76 KiB]
Downloaded 666 times
Author:  LarrySabo [ August 17th, 2016, 12:58 ]
Thanks. It sure is difficult finding any information about the program, other than by sending an e-mail to the author. Information like what are the features of the commercial version and how much does it cost, does it allow printing/exporting the file/folder list, etc. The freeware version lets you see the list of files/folders pruned by the customer, which is nice, but how does one work efficiently with that when it cannot even be printed/exported?
