| Seagate Arch ST10. Understanding of [CTRL] +[L] output http://forum.hddguru.com/viewtopic.php?f=11&t=34115 |
Page 1 of 1 |
| Author: | Maksim.Zaikin [ September 5th, 2016, 0:59 ] |
| Post subject: | Seagate Arch ST10. Understanding of [CTRL] +[L] output |
Hello evryone, kindly seek for your help in understanind of the [CTRL] +[L] command output, after i run i have following data: T>NHAWK2HD - 1_Disk 4.ADA 12-04-07 17:00 ADA,NH_1D_2H_S,14 Built for NHAWK2HD,PITKIN,Redback,TI1843 PreAmp,Agere7539 PreAmp,McKinleyLite,1Disk,220 Servos,7200RPM,8Pole,133MHz,RwFeat=0002,VBAR my questions are following: 1. What is NHAWK2HD,PITKIN,Redback ? 2. TI1843 PreAmp - is it preamp model or revision or anything else ? 3. Agere7539 PreAmp - is it preamp model or revision or anything else ? 4. McKinleyLite - what is this ? 5. 220 Servos - what is this mean ? 6. 133MHz - is it Preamp freq. or proc. ? 7. What is RwFeat=0002 ? 8. What is VBAR ? and the last q. : is which are parameters from the output are critical in donor search process ? Thank you in advance, regards Max. |
| Author: | xsoliman [ September 8th, 2016, 6:19 ] |
| Post subject: | Re: Seagate Arch ST10. Understanding of [CTRL] +[L] output |
Bump, as I would like to know as well |
| Author: | fzabkar [ September 8th, 2016, 16:29 ] |
VBAR = Variable Bit Aspect Ratio TI1843 PreAmp / Agere7539 PreAmp - preamp part numbers made by Texas Instruments (TI) and Agere NHAWK2HD - Seagate's internal name for the drive family |
