| MAXTOR HDD!!! Help!!! http://forum.hddguru.com/viewtopic.php?f=11&t=34347 |
Page 1 of 1 |
| Author: | olinyer [ October 17th, 2016, 11:30 ] |
| Post subject: | MAXTOR HDD!!! Help!!! |
Hi, I hope you are doing great. Behavior: 1. I have this MAXTOR which had the PCB power issues and before going to die the PCB it was giving the same error message of not able to start utility with message: Initialization error, Context: Read Roadmap, Content: Device Error Detected 2. With the new PCB (donor HDD or donor PCB (different one)) it is giving the same behavior. 3. Patiente HDD spinning sound it is very loud compared to a new one. Please find OLD HDD Info: Model: 2B020H1 HDA: 11B PCBA: 11A UNIQUE: 11C CODE: WAK21R90 OLD PCB INFO: POKER C.6 040108200 4370J2 0216S 4713843 4 ------------------------------- ***NEW HDD Info:**** Model: 2B020H1 HDA: 11A PCBA: 05A UNIQUE: 11A CODE: WAH21PB0 NEW HDD PCB INFO: 040104900 D741667BPGF EB-1AA45VW -------------------------------------- I went to find another PCB: NEW PCB INFO: POKER C.6 040108200 4370J2 0223S 1161125 4 Thank you for the help. Best regards, |
| Author: | data-medics [ October 17th, 2016, 11:34 ] |
| Post subject: | Re: MAXTOR HDD!!! Help!!! |
If it's much louder than the donor, then likely it's one of two issues. 1. The bearing is not spinning freely and it's not getting up to speed (less likely) 2. The read/write heads are severely damaged and are scraping the platters. Do you have a clean room to open and inspect inside the drive? |
| Author: | digisupport [ October 17th, 2016, 11:45 ] |
+1 for heads, do not power up before internal inspection. |
