| Need LDR for WD10JMVW-11AJGS1 fw: 0006000M http://forum.hddguru.com/viewtopic.php?f=11&t=34479 |
Page 1 of 1 |
| Author: | Alm [ November 7th, 2016, 15:50 ] |
| Post subject: | Need LDR for WD10JMVW-11AJGS1 fw: 0006000M |
Hi Could anybody please upload the firmware of WD10JMVW-11AJGS1 ? firmware version : 0006000M Thanks in advance |
| Author: | hyuce [ November 7th, 2016, 16:01 ] |
| Post subject: | Re: Need LDR for WD10JMVW-11AJGS1 fw: 0006000M |
you can find here http://files.hddguru.com/index.php?acti ... ty/Fblite& |
| Author: | Alm [ November 8th, 2016, 12:14 ] |
But this is 11AJGS0 |
| Author: | jermy [ November 8th, 2016, 12:33 ] |
Doesn't matter |
| Author: | jackass25 [ November 8th, 2016, 13:32 ] |
http://www.mediafire.com/file/chuahqemj ... 06000M.zip |
| Author: | data-medics [ November 8th, 2016, 14:03 ] |
Actually the entire model doesn't matter, or even the capacity of the drive. LDR is compatible across all drives of the same ROM revision and family. |
| Author: | mr_spokk [ November 10th, 2016, 7:07 ] |
data-medics wrote: Actually the entire model doesn't matter, or even the capacity of the drive. LDR is compatible across all drives of the same ROM revision and family. Shhh |
| Author: | Alm [ November 10th, 2016, 8:06 ] |
jackass25 wrote: http://www.mediafire.com/file/chuahqemjj1u7h8/WDC+WD10JMVW-11AJGS1-01-01A01-WD-WXA1E63FHRV1-0006000M.zip Thank you |
| Author: | Alm [ November 10th, 2016, 8:08 ] |
data-medics wrote: Actually the entire model doesn't matter, or even the capacity of the drive. LDR is compatible across all drives of the same ROM revision and family. OK , Thanks |
